draggat
- Jul 26, 2010
The Le Thiers knife was my gateway into French cutlery. You can't go wrong with Chambriard. They are slip joints with a transitional spring, weighted heavier on the opening snap and close. They also have the year of manufacture on the butt end. These are the most common ones available in the US and have a decent build quality, although I'm not sure where you are located?
Perceval knives are excellent quality, but they are also much more modern and their le Thiers has a liner lock. Fontenille Pataud is outstanding as well, with a lock back.
My personal favorites are the Cognet versions which come in two sizes and feature a slip joint mechanism with a half stop. Only the large version is available with bolsters and it is a bit on the heavy side. File work on these typically only shows up on the fancier, more expensive models. Ordering direct from them was a pleasant experience.
I have some by Goyon-Chazeau but I would not recommend them. Both of mine have build quality issues.... one came with the blade sitting 1/4" proud when closed and the other has a handle pin that was ground too far causing the handle to make a pop sound when squeezed.
Some photos.... Unfortunately I no longer have the Fontenille Pataud and my Perceval knives are different models. The laguiole is 11cm closed but keep in mind that sometimes the lengths appear different in these comparison photos. Best to look at the measurements of each knife independently.
Good luck!
Good luck!
