- Sep 20, 2015
So I finally got my Chaparral LW, I got the spring rate adjusted just right . . . then my dambed thumb split so much I can't enjoy the knife. I mean opening and closing the knife one handed is just more pain than I want to put up with for using my new knife.
Sure I use both hands to open it and the side of my index finger in the lock bar to close it but . . .
With a bit of experimenting I worked out some workaround :
You can see how the split has to run right into the edge of the scale to use the Spyder hole.
So I found I could use my index finger like a Spydie flick to get the hole away from the edge of the scale then I can get my thumb in there with less pain. By the way this is the way Spydie Chick (who is left handed) deals with some right handed knives and she opens them and closes them faster than I can and I'm right handed. Check her YouTube reviews out if you haven't seen them.
You can see here how working the lock bar is a problem, even after I took the knife apart and relaxed the spring rate some.
Some how I discovered this lock bar press without thinking about it. I'm still surprised it works. Might take a bit of trial and error but it gets more natural with repetition. My Chaparral drops when I press the bar so it is obvious how far to press the bar and it is less than one might think. Doesn't look like it would work but it does.
You got to kind of hyper extend the joint and move toward the blade with your thumb.
Pardon the mechanic's hands . . . I do scrub them. Less enthusiastically the more they split. You haven't really lived until you get the scrub bristles down in the splits then you know you are really alive ! ! !
