Last year I've started working on my 3V tanto and wakizashi, for HT contacted Peters and for recipe contacted Nathan. Because D3V protocol is proprietary, Nathan told me to tell brad at Peters to ht my blades with "low temper tweak developed by Dan and Nathan", also he told me that "Brad can heat treat your 3V with the protocol that immediately preceded the Delta protocol. It's a very good performer."
When I've asked about pre D3V and D3V he told me next "The chief advantage to the Delta protocol over the immediately preceding low temp tweak is enhanced edge stability in rough use. --->edge stability<--- not gross toughness. And the low temp tweak was already used for good edge stability and has a proven track record with Dan Keffeler's swords. Delta is not stronger, it stays sharp better. The previous tweak is a good process, perhaps just as good when used in a large knife."
Well everything happened, blade where HT'd, but because of some life problems I wasn't able to work on them till 2020. Firstly I've finished tanto as small knifes are easier to finish lol, now started polishing wakizashi.
Well honestly I wanted wakizashi as chopper, to chop the way in forest (+beauty of Japanese blades) and tanto as EDC hard user, but it came up too pretty for hard use knife lol.
So I'm pretty shy to ask you about this trade lol, I just want to trade my tanto for most basic Heavy Duty Field Knife or Delta 3V Field Knife with basic kyndex sheath.
My knife is unused, just sharpened after assembly. So looking forward to get "new" HDFK or D3V Field Knife for it.
Here are specs of my tanto:
CPM 3V, Pre Delta 3v low temper tweak heat treat protocol, 61 HRC
.157" (4 mm) thickness at ricasso
Total length 9.4" (24 cm)
Blade length 4.72" (12 cm)
Cutting edge length 4" (10.5 cm)
Scabbard length is 5.11" (13 cm)
Polished black buffalo horn handle with brass tsuba and habaki
Polished mahogany scabbard with black buffalo horn ring at mouth
Blade was hand polished with edm stones and then with sandpapers
As I have never used bladeforums I will post some documents to show authenticity of my 3v steel and HT.
Also I live in Georgia (small country under Russia), but it isn't problem to send and receive stuff from USA.
Also for sure I will go first and send my knife and I have no problem with waiting so as another side will receive it they will send their afterwards.
For all pictures go
https://imgur.com/a/DcRpSj1
