Archer Here
- Nov 2, 2008
The Doomsday Dark Ninjato II – Just Released
This is Version II of the Dark Ninjato. Stronger and even more durable than version I ! Exclusively offered at the SBG on-line store, designed by esteemed sword designer Jason Woodard and handmade by Scorpion Swords & Knives. This Double Primary ground American Tanto tip style piercing blade was designed to punch through modern armor or hide. It’s also fast enough and well balanced to easily slice into bears, wolves or whatever other dangerous thick hide may follow in after the apocalypse. This heat treated full tang one piece construction results in an EXTREMELY DURABLE and almost indestructible sword.
Stay tuned for Extreme Durability Test Video by esteemed sword tester and designer Jason Woodard!
Shop Details:
1095 High Carbon Steel. Steel is Heat Hardened & quenched. Heat Tempered @ 500 degrees for 2 hours, and letting it air cool.
Measurements:
Total Length = 32 ¾ “
Blade Length = 21 3/8 ”
Blade Width = 2 5/8 “ at the base
Blade Thickness = 3/16 ”
Handle Length = 11 3/8 “
Handle Width = 1 ¼ “ middle
Handle: Black Linen Micarta with Deer Skin Leather Wrap
Weight = 3.6 lbs
Shop Details:
Measurements:
Weight = 3.6 lbs
