Hey Gaston,
Is this your Lile Mission knife? The description sounds like your knife.
Yes it is.
I tried out both an old (oop) $99 United Cutlery (Taiwan made) and a $39 Master Cutlery (Chinese made, without sheath so cheaper), and I found they were both noticeably better made than the Lile, in almost every respect... They are both in 420J, and the edge holding is nothing short of great on both (no rolling or chipping tendency at all while chopping), barely behind in any way to the Lile's D-2 (which required a micro-bevel to avoid chipping, while the 420J essentially didn't).
The cheapos are both slightly thinner stock (0.23" vs 0.25" on the Lile) but the MC is definitely the strongest, heaviest bladed and burliest of them all overall (0.045" edge), while the UC has the thinner Lile-matching geometry of 0.030", and a more slender point (the UC feels noticeably lighter than the MC, maybe as much as 15 vs 18 ounces, the Lile being around 17). My biggest peeve with the MC was that it had a thinner handle diameter, but this was turned on its head when I realized it has a broader rope tube-end "lip" that allowed wrapping 550 cord over the existing cord (both original wrappings were comparable to Lile in tightness, but UC used a fuzzier lower quality rope that happens to grip slightly better).
Blade surface finish and grinding precision was far, far greater on these cheap knives than on the Lile (even the paint is better than what was originally on my all black Lile, despite the lack of sandblasting for grip).
The Lile dual grinder makes these "waves" as it goes over the teeth, my Sly II having had this all over (before the REK re-grind), even up and into the clip notches(!) (The Mission only near the plunge line, so much better...): The Liles are basically machine-made, while the cheapos are actually hand-made to a quite high standard: Edges on the cheapos are very consistent in thickness (but MC is too thick at 0.045"), while Lile edges (0.030" on the Mission and 0.042" on the Sly II) varied up-down and caused a lot of trouble sharpening, even on the Mission...
The cheapos teeth were of course not dipped, but REK dipped the split UC teeth for me (while adding a magnificient 18 dps edge) while I dipped the split MC teeth myself with a X-coarse dia-sharp (surprisingly easy to do just freehand).
The final nail in the coffin was the lie spread about the UCs that they have inadequate construction (a screw-in thin rat tail is shown in at least one article, and I posted a comment there that this was demonstrably not a UC blade shown): The UC has in reality a 0.23" thick full tube-width tang of about an inch long, secured with a pouring of shock-proof two part resin, just like many customs, including the Liles which are also similarly resin-locked(!)... Maybe the Liles have a more mechanically secure lock-up within the poured resin, as the UC might be purely dependent on resin adhesion to smooth inner tube surfaces, but the Mission guard is short and un-lugged, and the guard leverage is the main danger of causing the tube to break the resin's adhesion on impact: The cross piece can act as a separation lever, but the Mission's guard does not have the right shape or leverage to do this, so for all practical purposes the UC is essentially indestructible... Even if it moved, a running of crazy glue would fix it for at least 500 chops.
The MC has a metal piece surrounding a similar tang, and this introduces tolerance issues: My MC was probably a steal because this tang assembly rattled slightly, but I poured thin crazy glue into the tang, and it hasn't rattled in 500 chops: Even if the glue cracks, it only has to stay in place, and so far no glue residue is falling out... The MC blade is stronger than either of the others, but both copies lose a bit of point mass by having taller clip grinds: This is my only dislike vs the Lile: Other than that they are simply better in every way, right down to the MC buttcap being the most crisply machined, but none are interchangeable to one another, unfortunately.
So with all that, I kept my modded Lile sheath (for the UC, which fits it far better, owing the 0.23" stock, than the Lile ever did) and decided I'd be better off selling the 20X dearer knife...
It is unclear to me if the cheapo handle tubes are steel (Lile is), but the UC does feel much lighter overall than the MC. With the resin acting as a buffer, it probably doesn't matter.
UC vs Lile:
MC(left) vs UC
MC vs UC
UC vs Lile
Gaston
