Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Sorry there nothing wrong with your Case .
Well said. If someone has been a customer of Case for years, as the OP stated, I would think they would have come across more than one stockman but I don't want to assume that. Regardless, anyone that owns more than one Case would be able to tell a knife that was in need of an exchange or warranty work. I can't figure out if this thread was started to ask for advise on whether to send it to Case for repair, or just to bash Case. Which I for one would not appreciate.....
The spey blade is the best blade for roughing out the bowl of a wooden spoon if you use a traditional knife to whittle stuff like that. The stockman pattern is actually a pretty good whittling knife.
In this day and age more and more people will complain about something instead of sending it in. A lot of companies will stand behind their products and fix the issue or replace the knife. If the company refuses to fix it then you might want to post about it. Everyone makes mistakes and oversight does happen. Judging a company by one knife out of millions produced is probably a bad idea. More appropriate title for this thread "the problem with my case stockman".
Blade rub caused by the USER pushing on the blades (instead of pulling straight up) can happen with knives of any cost, including some high dollar custom knives. It depends on a lot of factors. But if the blades aren't touching then they won't rub at all unless you force them by pushing. That's a completely separate issue.
Jake, I don't agree. I open my stockman knives with the same pressures that I use for all my others. If that pressure is enough to cause the blades to rub so much that I can feel the drag, then I find that objectionable. I have lots of stockman knives where there is no dragging effect. I use the same opening technique for all of them.
Edit: My post broke the bladeforums database!![]()
I posted and then I got a database error message!
