- Mar 29, 2007
I figure it's time to start looking at the shop. Especially since I've had to redo a lot of it after our double annual rainfall in the past couple weeks. with 65mph max gusts!
Here's my current grinding table
On the right is my workhorse, a coote 2x72 with 10 inch contact wheel. The motor is a Baldor 1HP with a 4 step pulley arrangement and uses the motor weight for tensioning. I'm building a cart type table for holding this setup.
On the left is an old National Industrial Tools 2x48 with a grinding wheel. It's a 3450 rpm motor and is RIDICULOUSLY fast. If I can find a 1725 RPM motor that will fit the casing it will become much more usable. I may also at some point cut som heavy angle iron to mount the rig to and run a pulley system. The 2x48 isn't nearly as common as the 2x72, but if I can get it down from 5000 surface feet per minute to about 1000, it may become the edge grind finishing sander once stripped of the platen and tool rest.
This is the current 3 burner forge setup. It's honestly overkill and not as efficient as it could be, but I've learned to work it well and can hold a good heat with blade movements for soak times. I've got another forge body on a nice pedestal stand that I'm finishing up soon, I'll get photos of that up later.
