after using my Spartan Lite for a few days, i felt it was time to touch up the blades on my 204, mainly because it looks like i put a tiny ding in the front of the big spearpoint blade when i was prying out a PowerMac G5 tower plastic security rivet, it wasn't a chip, just a little bend in the edge
i ran the SAK down the brown stones at the 30 degree setting (5 passes on the corners, 5 on the flats) and it eliminated the ding, so i popped in the white stones on 30 degree, and did the same 10 strokes, 5 on the corners, 5 on the flats
i had initially sharpened the SAK on the 204 at the 40 degree setting, tonight i decided i wanted to go for a razor edge at 30, the bladesteel of the SAK isn't exactly the thickest, so it should handle the 30 degree just fine
the results were *amazing*, a nice, toothy yet smooth edge that cut through two layers of folded paper (a Buck 110 warranty pamphlet) like it was one layer, i then tried the "shave the hair off my arm" test....
i've read a lot about "hair popping" edges, but i had never actually *experienced* it until today, i had my desk lamp at just the right angle, and as i slowly pulled the blade across my arm hair, i saw the hairs *jump* at least 2" into the air as they were severed, it was a *shower* of arm hairs....
and yes, as expected, both arms are now bald *again*....
even the old, simple, faithful SAK can benefit from the Sharpmaker treatment, if you haven't tried it out yet, give it a try, the results will probably amaze you, they did me
yep, the SAK will be sharpened at 30 degrees from now on.... i could probably *shave* with this little SAK....
