- Apr 7, 2005
Are there any khukuri designed for throwing? I'm just curious about this.
Jack
Jack
ShadowchaserUFP said:Are there any khukuri designed for throwing? I'm just curious about this.
Jack
Daniel Koster said:wonder what Dave Rishar has to say about the subject....
Steely_Gunz said:Also keep in mind that a khuk's curved shape will mean that it will come back on you in a hurry if you miss the stick. At 1.5lbs, any part of that hitting you anywhere is going to be bad news.
Jake
My suggestion is what the others have said. get an AC and have at it. However, i think the thicker profiles will be harder to stick. I used to throw a Cold Steel Mini Gurka Lite with pretty good results. It's thin and with the heat treat it seems to hold up OK. no slabs to break off, and they can be had for 50 or 60 bucks i think. YMMV.
Personally, i'll stick to hawks and axes.
Jake
Bladite said:cold steel does have that Really Really Low End set of large blades with the plastic molded handles - people buying a kukri thing they're getting the better high end cold steels only to find a $16 stamped blade in their mailbox.
bladite
AstroErrr.........If it comes back at you, do you try to catch it or not ?
Steely_Gunz said:Thanks for bringing that upI forgot all about their "machete" line. Cheap enough to buy a couple. Good idea for a cheap thrower. I mean you can throw anything with enough practice. My first throwing knife was an old chef's knife, after all
Astro
Only if you can catch it in your teeth
Jake
