- Oct 2, 1998
Wow, no need to be that hostile, Steve.
I agree that apples need to be compared to apples, not apples to oranges. However, when you are discussing the tangs of two knives, and how they are secured, that's apples to apples, IMHO. The application for a Mission Titanium MPK, BTW, is to be used in situations where a magnetic signature is a risk to the user. In those instances, it's better to have a knife which is going to perform well but not at the peak levels of the super steels, than having a wonder steel knife that had to be left back at base because you would set off a Magnetic Impulse mine or other such hazard.
There's no secret that the Titanium MPK is not the answer to every (or even most) situations, which is why they are developing the A2 version. Comparing the A2 version to the standard ATAK is more along the line of apples to apples.
Here's what I've gathered from both sources:
Mad Dog uses Hard Chrome as a surface protectant. We've all seen the post where someone found a pin hole in their hard chrome and the blade snapped because rust ate away like cancer inside of coating. While it may protect against abrasion, it doesn't help against rust, IIRC due to the capillary action of how it's on there. Of course, I could be completely wrong here, but that's what I *remember* at this time. But, food for thought: all it takes is that one hole and the rust spreads underneath it, and no matter how well you take care of the surface, if it's under the chrome, you aren't going to see it until the chrome starts coming off.
Mission uses
We'll see what real world testing shows to this, Mission has never been shy to share their test results and where they are making improvements. Without seeing any actual test data on this, and if everything about the data provided is true, it would seem that Mission's coating is superior, at least on paper.
As for how secure the tang is in the handle, haven't there been a couple cases of the handle of the MD knife coming off? Especially when the rust gets under the handle? Furthermore, I don't have to wait until it actually happens to express my concern for the possibility of it happening in the first place.
Not having some kind of securing pin and having a tang shape like that would lead any reasonable person to conclude that when the glue fails, the knife is gone. Right or wrong?
From what I understand, Mission decided the same thing, and they changed the tang construction so that there was no way the knife could go flying out of the handle. IIRC, their tang shape is such that it's tapered to prevent this sort of thing, and on top of that, the handle is injection molded around the handle, yet is hard enough to pound nails.
Given the choice, I'd rather not worry about the handle falling off, but that's just me.
Now if there was a way to combine MD's ergonomics with the tang shape of the Mission MPK, I'm sure a lot more people would be happy, but then, Mission is striving for a handle that will work for the largest number of people, and the largest number of situations (i.e. lowest common denominator).
You can make all the claims you want about towing a pickup with piano wire, but to tell you the truth, I never had to do that when I was in the field, nor would I think anyone else has either. I have had to pound nails, and I can easily see someone running over the handle with a tank by accident, or all sorts of other abuse because, quite frankly, Joe Snuffy sometimes doesn't care for his equipment.
So, handlewise, what does this all boil down to?
MD's handles are harder and have better ergonomics for certain positions, if I'm reading Cliff's postings/reviews correctly. They also pose a problem if the glue fails or the chrome comes off and the knife blade falls out, because there's no pin or any other device holding the tapered tang in, just glue.
Mission's handles are hard enough to pound nails, which is hard enough for me. Mission also injection molds the handles over the tang, so the tang isn't coming out of it, period.
So, looking at the handle and tang construction of the two knives, I prefer the Mission Knife, especially if you factor in cost, wait time, and warranty. Like Cliff, I too would prefer a bit more hardness in the blade, but if it's easy to maintain in the field, I'm willing to make that sort of tradeoff.
Long winded as usuall....
Spark
Kevin Jon Schlossberg
SysOp and Administrator for BladeForums.com
Insert witty quip here
Mission uses
We are using an aluminum titanium nitride PVD (Physical Vapor Deposition) coating technology. How it works:
All material to be coated is enclosed in a vacuum chamber. This chamber is then gently heated to a specific temperature. Deposition material, in this case titanium, is vaporized by means of an electric arc. These now highly charged titanium ions are mixed with a nitrogen gas forming a plasma. This positively charged titanium plasma is attracted to the negatively charged part to be coated. Ion by Ion, the titanium bonds to the part, growing a thin, hard film on the surface. We can get up to 6 microns at between 3500-4000 Vickers hardness out of this coating. We ran a sample MPK last year and I could not scratch the tang even using a nail! Hard chrome has properties of about 1000 Vickers and 2.5-5 microns thickness. Based on all of our research, AlTiN should outperform hard chrome.
Spark
