Pretty sure he's not a fan so I usually hassle him, just because. I'd prefer it though if Spyderco's had sharpening choils for sure (easier with a guided sharpener like an Edge Pro or Wicked Edge) but since I've only ever had to strop/maintain my Fiddleback edges, its not as much as issue for me.So is Andy against a sharpening choil? Or should I even go down that road?
Whaaaat, no sharpening choils Andy??? hahahaha
Is there going to be an Esquire / Monarch shaped model that's in between the size of those two?
I do not like choils of any kind. Sharpening choils snag on things you cut like skin, cloth or string. Finger choils are a more serious functional flaw and steel a very important part of the edge of the knife when employed in a design. To do heavy cuts like notching for traps you need a lot of leverage on the cut. The part of the edge where it is easiest to get that leverage is directly by your fist. Moving the cut out an inch robbs you of this leverage. In addition, if your 4" blade or under design requires the ability to choke up to do detail work, your handle SUCKS and need to be re-designed anyway.
Horrid, choils.
Hey Andy, thanks for explaining that out! I knew you didn't like em but the specifics help.I do not like choils of any kind. Sharpening choils snag on things you cut like skin, cloth or string. Finger choils are a more serious functional flaw and steel a very important part of the edge of the knife when employed in a design. To do heavy cuts like notching for traps you need a lot of leverage on the cut. The part of the edge where it is easiest to get that leverage is directly by your fist. Moving the cut out an inch robbs you of this leverage. In addition, if your 4" blade or under design requires the ability to choke up to do detail work, your handle SUCKS and need to be re-designed anyway.
Horrid, choils.
Like Like Like (re: a model version between the Esquire and Monarch sizes)Its an idea...
yesAny plans for more stainless steel in the mix?
