Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
S7 is extremely tough, but isn’t a good blade steel.
For toughness with decent wear resistance that normal makers use look at 52100, Vtoku2, 3V, 1095.
For stainless toughness look to H1, LC200N and Elmax.
Not really. Powder metallurgy is used to control carbide size to get better combinations of properties. The key to toughness is to minimize carbide content. With a small carbide content the carbide size can be managed without PM. 8670 is tougher than 3V, for example.Are you referring to the budget steel article? If so, remember, it was BUDGET steel. I don't know if it would change anytjing, but adding PM and other hi-tech steels might change those results.
I don’t know what they use for cannon barrels. The question of “the toughest steel” and the question of what is a good high toughness steel for a knife are different questions.Larrin
Out of curiosity, what carbon steels and stainless steels are used for small arms and modern breech loading cannon barrels?
While I am sure they are "tough", I don't know if they would be good for a blade. I doubt they would, to be honest. Receivers and barrels are hardened to what? 40 something Rockwell C?
Wow man, surprised to get a reply by the person who wrote the article I was reading. Great work, I've been nerding out all morning!While talking about highest impact toughness (there are multiple measures of toughness) it would be a very low carbon, low strength steel. Low impurities, perhaps with nickel additions, especially if we are considering toughness across a wide temperature range.
Good to know about submarine steel,"4140
416R "
Yep. those are used in rifle barrels and such.
The really strong steels like the ones used for pressure vessels and submarine hulls will often have less than 0.2 % carbon. HY 100, Hy 180, etc. They are not inexpensive steels and need to be processed to be as clean and consistent as possible. Good steels for what they are used for but knife edges are not what they are good at.
The best thing to do is pick out which attributes you desire for your knife and select a steel accordingly. Then more importantly build it to do what you want it to do. All steels are a compromise. Select the ones that are best at what you want your knife to do and forget about being the best at any one attribute because that is where you find the least balance steels typically.
