Noel, civil discourse is the only way and I would not intend to be rude as I don't think you would either. So to the question at hand. You stated the following:
"Cliff,
A question, correction?
Hard Chrome is indeed a vapor barrier, it is chemically bound to the steel surface if I read the
http://www.hausnerinc.com/sealproc.htm
info correctly,"
Well, I hate to bring this up but no were within that url does it state that the hard chrome is a vapor barrier.
Secondly, it even states within that url that the use of hard chrome will help resist corrosion. they also go on to mention the food industry as a good use for their chrome. Since I know a little about the steel used in the food industry, let me explain. Nearly 100%(and of course there may be other stainless steels used also, but the point is stainless steel is used) of the steel used within the food industry is 304 or 316 stainless steel. This steel is extremely corrosion resistant but in the food industry extremely caustic solutions are used to clean equipment when a different batch of food may be run through the same equipment. Thus, even stainless steel as corrosion resistant as these can begin to show signs of corrosion. Putting hard chrome on top of stainless steel makes a good stainless almost impervious to corrosion, although not completely.
So, again, respectfully and with intended civility, hard chrome will resist but not prevent rust. When applied to a steel that offers literally no corrosion resistance by itself, it is a concern if the rust works it's way underneath the chrome were you cannot see it. you cannot remove what you cannot see.
Thus as for your quoting me about my original statement that I don't see hard chrome as an advantage, well I still firmly hold to that. I would rather see the rust develope and be able to take it off than to not see it and find out much much later. If I get a MD knife, you can bet I will treat it as if it were the least corrosion resistant steel there is, because I do not want it to rust without my knowledge.
I hope that it is understood that increased corrosion resistance is not the same as corrosion proof.
Noel, sorry if my writting sounded as abrassive as a DMT coarse stone, previously, I'll try to smooth it out.
