Does it heat evenly with no hotspot natlek
Or maybe your design might have cool spots at ends and hot spot in middle
Don't know if you have a way of testing that
Well , now I think that I can answer this question ................
Absolutely not hot or cold spot ....when moving thermocouple inside tube all I can see on screen is 2-4 Celsius difference .I mean from one end of tube to other end...
And I know why ..............
In conventional tube furnaces /Like Carbolite Gero mentioned earlier in this topic/ the temperature is generally uniform over only the central third of the heated length. Outside this region, the temperature decreases significantly due to heat loss at the ends , because the tube goes outside the insulation.....
In my case tube is FLOATING wrapped with ceramic blanket insulation from all sides and whole tube get same temperature all over ...
I finished bigger one with 65mm inside Dia. tube and 43 centimeters long .Now I see that I have no pictures of
completely finished oven , but all in all it is same as first one .Only change I make was that i used that 1800W HT elements from first/small one for this big one .On first one I have 1200W now ..It take one -two minute longer to get to temperature but I m ok with that ..
ONE more thing ...........@Stacy .......with only on/of switch
I LEARN to keep temperature on 800-803 Celsius forever if necessary .Of course I will use PID on this bigger one IF our friend @
Cushing H. make good tutorial for PID ...
Stainless steel need long soak so siting there half hour and playing with on/of switch I suppose would not be funny anymore
Tube ready to be wrapped.....
This summer i will make another one .......last one
with two tube jointed for swords , 86 cm long is enough ..
PS . What do you think is there difference between horizontal and vertical HT furnace ? I mean steel lies on the spine horizontally in the furnace or hanging inside tube ? This furnace can be used in both way ?
PSS .I didn't mention it here that I used small one for welding san mai ....It is amazing how fast steel get to temperature ,especially after being put back in again when the forging temperature drops... I can keep door open and there is absolutely no drop of temperature , only first inch, inch and half is little cooler . I didn t see any problem using it on 1200 celsius .Max. temp. I try was 1250 and tube hold just fine ...
