By your logic Worksharp's recently released roler is also a knock-off product. Right?And to boot, this is a Knock-Off (probably cheap Chinese) of a German product that has been around since 1993 called the Horl
Hmmmm,.... why thumbler is a cheap knock-off?It seems that the Horl and Work Sharp might be about comparable quality but the Tumbler is still a cheap knock-off.
This only works if the guy who made the Tumbler patented it officialy and he is paying so he can have a patent.My meaning above was a cheap-not-licensed-possibly-breaking-patent-copy
Do you know you can get hair whittling edge with #600 diamond plate?I know I am not as passionate or knowledgeable as many of you at this forum, but I would consider 600 grit to be a coarse grit for steel blade knife sharpeners.
That all depends on which grit rating standard is being used. A quick look at the grand unified grit chart, in the stickies at the top of this forum, shows the 600 grit can be anywhere from 10 to 30 microns. Depending on the standard being used. In the JIS standard 600 grit is 29 microns. In the FEPA-F standard 600 grit is 10 microns. Both are very commonly used standards. A DMT corse stone is listed as 45 microns, a fine is 26 microns, and an extra fine is 9 microns.I know I am not as passionate or knowledgeable as many of you at this forum, but I would consider 600 grit to be a coarse grit for steel blade knife sharpeners
This info is helpful, but not always welcome. I like standards that are standards. Old school I know. I do thank you for posting this.That all depends on which grit rating standard is being used. A quick look at the grand unified grit chart, in the stickies at the top of this forum, shows the 600 grit can be anywhere from 10 to 30 microns. Depending on the standard being used. In the JIS standard 600 grit is 29 microns. In the FEPA-F standard 600 grit is 10 microns. Both are very commonly used standards. A DMT corse stone is listed as 45 microns, a fine is 26 microns, and an extra fine is 9 microns.
O.B.
Again, It depends on what scale we are talking about. I wish there was one standard that every manufacturer of sharpening stones used. But there isn't. It almost seems like each manufacturer makes up their own grit rating. It's not quite that bad, but almost. Micron size of the grit, when available, is the closest we have to a universal standard. Mr.Wizard has put a lot of work into compiling the Grand Unified Grit Chart. It's a great resource. I suggest using it.This info is helpful, but not always welcome. I like standards that are standards. Old school I know. I do thank you for posting this.
Do you happen to know if what I mentioned above is correct ? That diamond grit sintered can only go up to about 1200 grit ? (I don't remember how many microns).
I just want to have sharp knives.
For examples of the above confusion; The basic definition of steel is : iron with carbon and possibly other metals. Yet knife steel is listed as carbon-steel, stainless steel (added chromium), and countless other steels with various alloy mixtures, but in many cases, the bottom line can be the Rockwell hardness (yay, something seems to be consistent) resulting from the heat treatment. But, I know I could be wrong about that also.
Thanks for the link to the Grit Chart ! I can learn from this.Again, It depends on what scale we are talking about. I wish there was one standard that every manufacturer of sharpening stones used. But there isn't. It almost seems like each manufacturer makes up their own grit rating. It's not quite that bad, but almost. Micron size of the grit, when available, is the closest we have to a universal standard. Mr.Wizard has put a lot of work into compiling the Grand Unified Grit Chart. It's a great resource. I suggest using it.
O.B.
I am glad that you find my chart a valuable resource! Please note that the Grand Unified Grit Chart is actually the predecessor and inspiration for my chart, which I named the "Grand Logarithmic Grit Chart" in homage though it is more commonly referenced by its title: Abrasives in Micron Scale.Again, It depends on what scale we are talking about. I wish there was one standard that every manufacturer of sharpening stones used. But there isn't. It almost seems like each manufacturer makes up their own grit rating. It's not quite that bad, but almost. Micron size of the grit, when available, is the closest we have to a universal standard. Mr.Wizard has put a lot of work into compiling the Grand Unified Grit Chart. It's a great resource. I suggest using it.
O.B.
