https://en.wikipedia.org/wiki/Plasticity_(physics)
Low-carbon steels have more plasticity - they can self-cure groves of abrasive grains. High-carbon steels have less plasticity. I'm not a metallurgy expert, it's just my assumptions.
Hi,
How could self-healing explain a 250 micron abrasive being 3 times slower than 125 micron abrasive?
I'm pretty sure it doesn't work like that, just look at any relative grindability chart (abrasion wear resistance).
The softer metals always grind easier/faster than the harder metals.
The higher the carbide volume, the lower the grindabilitity, it takes more time/pressure to remove material, less is removed with each pass , more abrasive wear resistance.
It holds for alloys/coatings...
Manufacturers selling CBN wheels say they're for hardened steel 50HRC and harder
wade7575 is sharpening M2, and diemaker is sharpening 440C, both are high carbide volume (5%+) so not exactly "plastic"
I have started to gather information from different sources after Wade message. I want to learn something new just like everyone else here. When we understand the limitations of extra coarse grits, we will edit descriptions. It's definitely not about "50 grit is bad for everyone".
Hi,
I look forward to seeing what you post, esp what the manufacturer has to say regarding the pressure .
I too am a big believer in everything is useful for something, but what is that for this stone?
Or for 250 micron grit superabrasive stones (diamond/cbn stones) ?
Or for any kind of 250 micron grit sharpening stone?
What is the advantage of larger grain size if its not speed?
As a next experiment for wade/diemaker, maybe compare ~250 micron sandpaper to ~125micron sandpaper,
or only ~250 micron sandpaper to ~250 micron cbn/diamond (see if sandpaper is faster than cbn/diamond).
