Is the swedge a standard? Because I don't have seen any uf without.
Excellent, I see that double-edged was an option!
(Based on the last pre-order, I'll have what Gus is having...)
Hi Nathan, are you doing any tweaks to the 3D handle shape for UF2? Kinda like the change from light chopper to medium chopper - small change visually but big improvement in hand.
If there are just a few I will grind the standard UF into a double edge. However, if (like last time) there are a larger number of double edge ordered I will probably offer a variation of the UF that is a dagger ground double edged fighter. Those were a bear but they were pretty cool.
www.bladeforums.com
Wow, those sheaths are amazing. Almost worth it to get the UF just to have an excuse to order a fine pair of pants like that. As if I needed another reason to get a UF.The difference between the two, I think.. Needed a reminder myselfUtility Fighter Appreciation Thread
www.bladeforums.com
That link is very helpful and answers a ton of questions.. I don't even remember the previous UF pre-sale. I think I was drunk that month.Yeah, a swedge is standard. It will be the same as the last run of UF except I've made a few small tweaks.
The previous run: https://www.bladeforums.com/threads/closed-pre-order-6-utility-fighter.1633754/
Same pricing, same options etc. except I don't think we're going to do the "utility field grade (as machined)" finish. We'll add about $10 bucks to the price of the basic configuration to cover a basic grind to remove the tool marks before tumbling. You people have spoken. Also, unfortunately, we'll probably need to add about 5% over the original pricing because it has been a couple years and materials and labor went up. Inflation happened and we all gotta eat. But the new run is fundamentally the same as the old run.
I am curious about this also MatSorta rhetorical question based on Nathan stating recently that extra options such as swedge and penetrator tip slow down the preorder process, my take from that being Nathan may not be keen on splashing this preorder with too many options but I’ve still gotta ask:
Will there be an option for a any sharpened top along the swedge lines ala a double edge version? My one regret from the past being not scoring one of those OG double edge versions (not DEF, I’m covered there) when I kinda had a chance to![]()
