I too make my initial plunge forward of where I want the final. Then I have plenty of meat to work with.
However, one knife I started way forward and got the plunge perfect in one try. That left a large ricasso. I'm more prepared to tell the customer it's to his advantage, rather than re-do the plunge.
FWIW, here's what I'm doing now.
I leave 1/4" plus extra ricasso area and rough the grind out with 80 grit. Then I smooth it out with 120.
Next I mark the edge where the plunge goes. Now with the work rest on and the belt perfectly on the edge of the platen, I carefully, slowly angle the blade against the belt. I'm cutting ONLY the ricasso area. The angle of the blade is such that I only cut about 1/4 the distance of the full grind and match up the edge thickness (Did that make sense?) Then work the grind line up to match the previous one. Then do the other side.
This creates a very sharp plunge cut.
Once two plunge lines are even and the grind lines are matched, I move on to the 220 belt and smooth bevel and shape the plunge.
Steve
