Victorinox 58mm Mod
Here is my 58mm mod, basically I wanted a less fat Minichamp. I call it the Diet Minichamp :) Built from a Signature, Jetsetter, and Cavalier.
I used 1/16 brass rod as a replacement for the stock 1.5mm brass rod (close enough) and likewise a 1/16 drill bit to drill them out.
Creating a jig out of a scrap block of wood is essential or you will hate yourself trying to circumcise a mosquito with all these tiny parts lol.
Having a rivet setter is also helpful.
Also tape it closed with painters tape when you are drilling the pins out bc everything will go flying.
Donor kidneys
On the jig
Collars removed and pins ready to be drifted
Assembly
Checking for gaps
After you put the collars on one side put some tape over that side so when you flip it to add collars to the other side they dont fall off
This is my Diet Minichamp. I wanted all the thin tools on one side so thats why the nail nicks dont perfectly line up. Oh well works for me. I really want to do some more mods but next time with Alox scales. Those are actually easier because you don't have to mess with collars.
Donor kidneys
On the jig
Assembly
Checking for gaps
Nice job. Did you have to get new collars and scales? If so, did the new collars need the holes enlarged? Likewise, did the holes in the blades need to be enlarged? If so, did you have any problem drilling the stainless blades? Were your pins headed with spinning tool or a hammering tool? Thanks!
I used the original collars and scales, I was careful not to damage them. I headed the pins by hand with a rivet setter. The holes in the blades and liners were not altered. The 1/16 rod fit just fine without any sanding.
View attachment 1181400 View attachment 1181399 Thanks for the information. I have a couple of projects in mind. One is to switch the sandpaper files in Money Clips to real files. Another is to make Titanium side plates for some Italian lobsters.
The original Money Clips had cut files. I have some non-clip SAK’s with real files. I want to swap parts, and I have spinning headers for pins. The Italian knives have 5 blades, but the only one I am interested in is the flush cutting curved jaw cuticle nipper.
The red Money Clip and the folding nipper have been carried for 20 years and are my most used knives.
Donor kidneys
On the jig
Assembly
Checking for gaps
I am a noob to this. But I want to take 2 narrow blades of a Minichamp and replace with a Philips \ caplifter tool. (-cuticle & emergency blade.) I am curious, what rivet tool did you use?
