- Sep 5, 2005
The Spartan Lite is a 91mm three layer SAK with a built in LED flashlight powered by two 3V lithium batteries. It has translucent scales. My biggest concern with this knife was that the flashlight wouldn't be bright enough to be useful. It's no Q-Beam but it's not bad. It's easily enough to read by and can illuminate a totally dark room well enough to get around. The owner's manual says that the batteries will last two and a half years under normal use. I'm very pleased with the tools that Vic chose for this one. It has large and small blades, a can opener, a bottle opener, three sizes of flat head screw drivers, a phillips screw driver, an awl, a corkscrew, a wire stripper, a key ring (is that a tool?), the afore mentioned flashlight, tweezers and a tooth pick. The phillips and large flat head screw drivers open all the way out or stop at 90 degrees for extra torque. The fit and finish are very good. I'm more than happy with it so far . I think I'll go open a bottle of wine with it right now.
