Hello
I was asked last week for more details on what VSD's (Variable Speed Drives) to get and where to get them.
WHERE TO GET VSD'S
Most of the manufacturers of VSD's are large companies that sell through a distribution network. Look in your local yellow pages under "electrical supplies", "electrical wholesalers", "electric motors", "industrial equipment", "electrician (industrial)", "electrical contractor (industrial)" or some such category. I have noticed that the different companies that compile the yellow pages for different areas use slightly different names for the categories.
You want to find a place that sells to industrial electricians. Home Depot is not going to carry motor drives. It should not be necessary to go outside of your local area to get one. There are a number of different distributors of motor drives where I am living now (a city of 50000 in rural New Zealand). While one of the other members of Bladeforums can give you the contact details for where they got a drive, there are advantages to dealing with someone local to you, especially if the supplier can also do the installation (if required). They can help you select the cables, circuit breakers etc. that you may need.
Ask some industrial electricians or contractors. They may be replacing some drives and motors in some factory.
WHAT VSD TO GET
The voltage ratingof the drive must match the supply that you have in your shop. Most of you will have a 110V single-phase or 220V single-phase supply. A few of you will have 220V three-phase supply. Virtually all of the models listed below have versions that will work for you If you have a 400V, three-phase supply, but I will not list them to save space.
Next, choose one that has output power and current ratings that matches, or slightly exceed, the power and current ratings of the motor you are going to be using. It may be easier to choose a motor after you have chosen the VSD. Note that some of the model ranges cut off the 110V models at lower power levels than the corresponding 220V model ranges.
Determine whether or not you want a brake function. With a brake, the VSD can make your grinder stop very quickly instead of allowing it to coast to a stop.
Determine if you would want a remote speed control (potentiometer) or remote keypad. I forgot to note which models offer this feature.
Determine if you would want remote control switches for on, off and maybe reverse. It is very handy to mount these right next to or on your grinder.
Consider the possibility that you may need an EMC or RFI filter. Most of you have shops in a residential setting. A VSD that interferes with the operation of the radios, stereos and TV's in your house and that of your neighbors is likely to make you unpopular.
Take a list of the above features and shop around. Think about if the supplier can help you set up the VSD properly. It may be as simple as giving you a few tips about which pages in the manual to focus on.
The following is a list of companies that I feel are reputable and manufacturer VSD's that will work with 110V single-phase, 220V single-phase and 220V three-phase supplies. This list is not exhaustive and not all of them will be represented in your area. Unfortunately, I am not in a position to compare the price or performance of any of these VSD's. Do checkthe features and specifications with the distributor. I may have made some errors.
Allen Bradley (www.ab.com/drives)
160 series
1-phase & 3-phase, 240V, 0.5 - 5hp
optional EMC filter
PowerFlex 4 series
1-phase, 110V, 0.25 - 1hp
1-phase & 3-phase, 240V, 0.25 - 5hp
optional EMC filter
Reliance (www.reliance.com)
SP120 series
1-phase, 110-120V, 0.25 - 1hp
1-phase & 3-phase, 200-240V, 0.25 - 5hp
MD60 series
1-phase, 115V, 0.25- 1hp
1-phase, 230V, 0.25 - 2hp
3-phase, 230V, 0.25 - 5hp
optional EMC filter & brake
Fuji Electric / GE (www.geindustrial.com)
AF300 C11 series
1-phase, 220 - 230V, 0.125 - 3hp
3-phase, 200 - 230V, 0.125 - 5hp
optional EMC filter & brake(?)
VAT20 series
1-phase, 240V, 0.25 - 3hp
3-phase, 230V, 2 - 3hp
AF300 E11 series
1-phase, 240V, 0.125 - 3hp
3-phase, 240V, 0.125 - 10hp
optional EMC filter and brake
AF300 M$11 series
optional EMC filter, brake, remote keypad, NEMA4 splashproof enclosure
Toshiba (www.tic.toshiba.com)
S9 series
1-phase, 200 - 230V, 0.5 - 3hp
3-phase, 200 - 230V, 0.5 - 20hp
E3 series
3-phase, 200 - 230V, 3 - 60hp
H3 series
TB Woods (www.tbwoods.com)
XFC series
1-phase, 115V, 0.5 - 1hp
1-phase & 3-phase, 208 - 230V, 0.5 - 5hp
optional remote keypad, NEMA4 splashproof enclosure
Mitsubishi (www.meau.com/eprise/main/Web_Site_Pages/Public/Products/VFD/P-VFD-Family)
S500 series
1-phase, 115V, 0.12 - 1hp
1-phase, 200 - 240V, 0.05 - 2hp
3-phase, 200 - 240V, 0.12 - 5hp
E500 series
3-phase, 200 - 240V, 0.12 - 10hp
Square D / Schneider Electric (www.squared.com)
Altivar 28 series (same as the Toshiba S9 series?)
1-phase, 208 - 230V, 0.5 - 3hp
3-phase, 208 - 230V, 0.5 - 10hp
optional EMC filter & brake (?)
VSD07 series
1-phase, 120V, 0.25 - 1hp
1-phase, 208 - 230V, 0.25 - 1hp
3-phase, 208 - 230V, 1 - 2hp
Delta (www.deltadrives.com)
VFD-S series
1-phase, 90 - 132V, 0.25 - 1hp
1-phase, 180 - 264V, 0.25 - 2ph
3-phase, 180 - 264V, 0.25 - 3hp
ABB (www.abb.com)
ACS100 series
1-phase, 200 - 240V, 0.25 - 3hp
3-phase 200 240V, 0.25 - 3hp
ACS140 series
WHERE TO GET VSD'S
WHAT VSD TO GET
160 series
optional EMC filter
PowerFlex 4 series
optional EMC filter
SP120 series
MD60 series
AF300 C11 series
VAT20 series
AF300 E11 series
AF300 M$11 series
S9 series
E3 series
H3 series
XFC series
S500 series
E500 series
VSD07 series
VFD-S series
ABB (www.abb.com)
ACS100 series
ACS140 series
