- Mar 8, 2016
Did some searching but couldn't find anything. Does Nathan have a warranty of any sort on his products?
I haven't formalized a warranty in most cases. Some knives, such as the Heavy Chopper and the Shiv, are covered for anything short of intentionally breaking it. I will replace, repair or refund. Broken tips are re-pointed, broken scales are replaced with a material of my choosing. So you can throw it, pry with it, use it to bust down a brick wall, it will not fail. <--- that's the rough use knives and I've offered it to early adopters of "regular" knives too, so the folks who agreed to be a guinea pig on new models are offered to return their knife at any time in any condition for any reason for a full refund.
On the other end of the spectrum is the Potato Knife, which is covered for material and workmanship only. It's fragile.
I don't believe in making indestructible knives because they don't cut well. A good design is a balance of cutting performance and durability to make a quality reliable tool that works well for a competent user.
Throwing a Field Knife won't void the warranty in general, but if you break the point off while throwing it don't expect a replacement - it's a hard utility knife, not a throwing knife.
The Field Knife is covered for batoning. That said, if you split wood with it all winter and wail on it mercilessly for days I wouldn't be surprised if someone could eventually break one. I haven't been able to, but I'm sure it's possible - it's 3/16" and HRC 62. And I would replace it because that's an acceptable use.
Cutting nails is not an acceptable use. I would cover a Shiv for that, but a Field Knife is a cutting tool, not a cold chisel. Yes, it will do it. But if you have a job breaking down pallets and you need to cut through a lot of nails, it wasn't really designed for that. The thick geometry and lower hardness required to do that well would be an unreasonable compromise in cutting and edge retention performance for that particular knife.
I make very durable high performance knives that will tolerate a lot of abuse, but I will not get into the "sharpened pry bar" zombie slayer market, it's already well served.
I like a common sense approach to this. If you're using your knife to cut copper wire, pry staples and baton wood these are reasonable rough use which is why you buy a good knife, so you don't have to worry about babying it. But if you're doing something really stupid and you break your knife, well...
After watching what Nathan puts his knives through in his videos.....what are you thinking of doing with your Field Knife that would come close to that?
Just curious as to how you use your knives, heavy emphasis on the 'knife' part....
I will use the knives for light carving, feather sticks, very light batoning for smaller kindling, small food prep and general cutting tasks for EDC.
Hey EBP you are from Australia right? I remember reading it somewhere. And you can edc your knives? You must live near the country somewhere? Man i wish i could edc knives, but i am from Sydney city. I can only edc when i go to work but that is about it. Besides that i look for excuses around the house to use my knives.
On a side note- A friend named Paul who had no common sense used his Paul knife to arc the starter on his car
This small folder. I had one and he wanted one because it was the same as his name:He used his paul knife ??
Sorry, i am genuingly curious, which knife did he use to do that, and open his house door?
