- Aug 13, 2002
A promised, I tested 3 water based cements and a regular solvent-based one. I used some scrap leather I had and it was a little dry so it ripped pretty easily but it still gives a good enough idea to compare the cements.
I did 3 strips for each:
1) Skin-Skin: Skin sides together, one coat of cement
2) Skin-Rough: Skin to rough side, one coat on the skin side, 2 coats on the rough side.
3) Rough-Rough: Rough sides together, 2 coats on each.
(Note: The number of coats were as per Mr. Long's instructions in his DVDs which I highly recommend by the way)
All the cements were let to dry as instructed on the containers. Water based did take a little longer to dry but not as much as they said one some containers.
Individual results:
1) Tandy Ecoweld
Skin-Skin: Came unglued
Skin-Rough: Came unglued
Rough-Rough: Glue held, leather ripped
(Disregard the 4th test)
2) Tandy Craftsman LG2 (at the store they told me it was discontinued)
Skin-Rough: Glue held, leather ripped
3) Lepage Regular Contact Cement
4) Lepage Low-Odor (water-based) contact cement
Skin-Skin: Came unglued (but got the best results of the 4)
Here are the 4 on order of how they performed from worst to best.
4th Place: Tandy Ecoweld
Very disappointing. Lowest adhesion of all of them
3rd Place: Lepage Regular Contact Cement
Another disappointment. This was suppose to be my control to compare the water-based cements by and it did not perform as well as 2 of them.
2nd Place: Tandy Craftsman LG2
One of the 2 best but came in second place because it did not perform quite as well as the winner in the Skin-Skin test and may be discontinued.
1st Place: Lepage Low-Odor (water-based) contact cement
A clear winner, in this test anyway. Best adhesion in all the tests. Plus it is easily available at your local hardware store. Well in Canada anyway, not sure about the US but I am sure that you also have a low-odor version of the commercial contact cement available in the hardware stores and I don't see why it would not perform as well.
Conclusions:
I did not test Barge contact cement, which is the one you see mentioned most of the time for leatherwork but given how the Lepage low-odor faired and the fact that it is just a pleasure to work with (goes on easily, no smell, everything washes out with water) I will definitely be using it from now on. I also don't know how it would perform if you were to thin it with water but given it's already milk-like consistency I don't see the need except to revive an old batch. Something that I also don't see the need for given low price and availability.
When I get the time I will do the test again with fresh leather to see if it makes any difference. I'll post the results on this thread.
I hope this has at least peaked your interest in the water-based cements and hopefully enough to give it a try. The more people who try them, the better we'll know how they perform and maybe we can save ourselves a brain cell or 2.
Feel free to add your own results and thanks for reading.
Individual results:
1) Tandy Ecoweld
Conclusions:
