Thank you. I already show this image to Beaumont Metal works. They said it's normal. But I also wanted to hear the opinions of the users.First, contact Beaumont/KMG. Tell them what the issue is and show the photo.
Second:
Make sure the belt is tight enough. If the tension is too low the belt will move to the side as you apply pressure in grinding. That can expose the edge and you will be rubbing the blade on the rubber ... which will make those marks.
Check the tracking. It should be even on both sides or just a tad to the right ( for right handed people). If the belt is not tracking right, it can expose the edge and you will be rubbing the blade on the rubber ... which will make those marks.
If the belt wobbles (usually caused by a cheap belt or a bad seam) it can expose the edge and you will be rubbing the blade on the rubber ... which will make those marks.
IMHO, my tracking was perfect. I don't think that scratch was caused by a blade.
