- Nov 15, 2005
So, I started a thread (here) last month to talk about West System's G-flex epoxy verses Bob Smith Industries (BSI) Mid Cure two part epoxies.
It sounded like some testing was in order!
Setup:
Edit: I know this testing wasn't perfect... Just doing the best with what I had!
Cheers,
James
Setup:
- Two square pieces of linen micarta affixed to two square pieces of 1095
- Surface prepped on granite with 120 grit paper
- Drilled holes in all 4 pieces for pull part testing
- Scribe'd lines in the pieces for proper over lap alignment
- Cleaned the surfaces with alcohol before glue-up
- Mixed both glues for 25 seconds before application
- Used 2 spring clamps of the same manufacture on each sample
- Cured both samples @ room temp for 24 hours
- Froze the samples for 12 hours
- Baked the samples at 180 for 2 hours
- Performed static load testing @ 135 and 225 lbs
- Attempted to perform dynamic load testing with 135 lbs for ~ a 12'' drop
- Micarta busted before the samples parted!
- Ran the samples though the dish washer twice
- Did a "smash test".... #trademark
- Finally... did a vise/lever/break test
- The samples were indistinguishable in performance all the way up to the lever-break test.
- The vise/lever/break test appeared to show that the G-flex sample took more force to break off and "flexed" more during the break test.
Cheers,
James
