- Mar 19, 2001
I use the Sharpmaker and some freehand. And ALWAYS Sharpie the edge on the first few sharpening sessions on a new blade! I've never been attracted to a full-on guided system.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Yes I use the TSPROF Blitz 360 for reprofiling and initial sharpening and it takes all the stress out of sharpening a sebenza it is clamp system and works great with an angle cube. The thing to be aware of is you must use a sharpie to first find your angle and you must use a digital angle cube to discover where you are at and you must recalibrate the cube for each side as the clamp will not give you the same degree on the opposite side. I have seen there be as large as a 3 degree difference. That is not due to the factory grind it is due to the way the clamp can not evenly hold a sebenza.With so much caution being expressed about the edge pro and the Sebenza is there a fixed angle sharpener that you guys recommend?
I've reverted to sandpaper on leather since I couldn't get mine sharp on on my flat diamond stone. The sandpaper on leather works fine for now but I don't think it's going to be a long term solution.
Is the best option then to sharpen by hand on a wet stone? Or use something like a Ken Onion belt sharpener?I've used it but not on a CRK. It definitely creates a convex edge, although it may not exactly match the geometry of the factory edge. Overall it's a slower process because you have to allow the stone to run its full length over the edge. You can't use the sawing motion that you'd employ with the flat stones.
