Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I just had a look at a different website and I found a range of different sized AEB-L from Aus $75+ which is within my budget. Here is the website: https://www.artisansupplies.com.au/product/stainless-steel-aeb-l-3-3-x-50-x-1220-mm/ . Sorry for stating the wrong price for this steel300 AUD for how much AEB-L? I typically count on a piece of AEB-L big enough for a 210-240mm gyuto to cost around $6.50-7.00 US. An 8 x1.5 x .118 piece would cost you a bit over $3.
Gregor I would steer clear of the 12c27 available in Australia I got some via Gamecos artisan supplies at a really good price. The kicker was it was sheared from previously rolled steel and anytime it got near any heat it warped. I found out subsequently 12c27 is sometimes known as memory steel because it wants to go back to its rolled state. Even grinding off the "skin" on the steel first didn't help. Unless you are good at controlling warp then I would stay away from 12c27. As a beginner I have used D2 (almost stainless) but it is a lot of work to finish by hand once hardened and am now using A2 both available at reasonable prices in Aussie and no more difficult to heat treat than stainless. I paid less than Aus $55 for a piece of A2 3.2 x 38 x 900Sorry for not specifying what I will be doing with the knives. The knives that I am planning on making are small bushcraft/neck knives, that will probably be used for light bushcraft and general everyday use around a farm. Thanks for all the helpful suggestions! I live in Australia and the steel that you guys have suggested - Aeb-l - costs Aus $300+. 154CM looks pretty good and is not to expensive, so I will definitely consider this steel. What about 12c27? Is it any good? Thanks for all the help!
Thanks for that Kevinc. I was looking at artisans supplies aswell. So with A2 how good is it at avoiding rust? Gough customs on YouTube said that he uses it on his production knives, so is it really that good compared to other steels?Gregor I would steer clear of the 12c27 available in Australia I got some via Gamecos artisan supplies at a really good price. The kicker was it was sheared from previously rolled steel and anytime it got near any heat it warped. I found out subsequently 12c27 is sometimes known as memory steel because it wants to go back to its rolled state. Even grinding off the "skin" on the steel first didn't help. Unless you are good at controlling warp then I would stay away from 12c27. As a beginner I have used D2 (almost stainless) but it is a lot of work to finish by hand once hardened and am now using A2 both available at reasonable prices in Aussie and no more difficult to heat treat than stainless. I paid less than Aus $55 for a piece of A2 3.2 x 38 x 900
kevinc
I might have to buy some AEB-l to see how good it really is. Seems like an excellent steel choice. Thanks for all the help!i am a decent knife maker, but not a very good sharpener. With that said, i had an AEB-L gyuto at like 61Rc that I had taken down to like .007. I knocked the corners off with a worn 400 grit belt and low speed and then spent less than 10 minutes on a King 1000/6000 stone and a "flesh side" leather strop from Woodcraft loaded with aluminum oxide powder. The knife will now push cut a tiny 1 x 1.5 piece of the very thin bag paper that you get from Starbucks when you order a muffin while being held out with two fingers grasping one end. I love this crazy Swedish stuff!!!!
Does it require much maintenance? Like oiling?A2 will make a great blade if it's dealt with right
Yeah I've realised that its going to cost me a packet to make the kiln. I have been given a bit of funding from my relatives and parents to go towards purchasing a steel, so all i have to pay for is the kiln. I am hoping to make a kiln capable of temperatures 1100°C. Is this hot enough?Question: DOES it have to be Stainless Steel?
The reason I ask is that you are not yet able to do heat treatment required for stainless blade steel. You still need to build a furnace capable of reaching Austinzing temperature and on top of that you will need Stainless Steel FOIL to wrap the blades prior to heat treating to preserve the surface and keep it clean. All of these items will add up quickly. A DIY Furnace with PID controller and thermocouple will run about $400-$500 before you ever get to purchasing steel. Unless you can find someone local to do your heat treating you might want to rethink Stainless.
I live on the island on the west coast, and my EDC for all of last year was a bird and trout knife made from A2 with a mirror finish.Does it require much maintenance? Like oiling?
Ok thanksYes if you can reach 1100C and maintain you will be fine. That is a bit higher than you will need to Austenize any of the stainless that's been discussed but that is not a bad thing.
That suprises me. Good steel then. Thanks.I live on the island on the west coast, and my EDC for all of last year was a bird and trout knife made from A2 with a mirror finish.
I might have oiled it once all year, and it got uses constantly. No rust issues.
It's not stainless, but is fairly stain resistant as far as carbon steels go
Hahaha niceI liked AEB-L before it was cool.
GregorThanks for that Kevinc. I was looking at artisans supplies aswell. So with A2 how good is it at avoiding rust? Gough customs on YouTube said that he uses it on his production knives, so is it really that good compared to other steels?
