Looking good .Fresh Off My Workbench :
Survive GSO 5.1 that I just reprofiled and sharpened for a good customer here at BF. This one has beautiful multicolor micarta scales and the blade is made of Magnacut. 15 degrees per side edge bevel, from the factory it measured right around 20 DPS.
I did the reprofiling work and also finished the apex on my Tormek T8 with the SG-250 grindstone, which leaves 220 grit finish. Deburring was done on the same wheel by setting the edge angle 1 degree higher. My assistant rotates the wheel by hand slowly as I take very quick and light passes alternating from one side of the blade to the other. The key is not to overgrind and create a new burr!
A handful of passes on each side and you are left with an edge which is shaving sharp and will pop hairs off your arms yet also retains excellent slicing aggression and edge retention. This is the configuration I prefer on general use knives where most of the cutting will be done on a slicing or draw cut rather than a true push cut. Not the best choice for woodworking, but for general utility it's great.
View attachment 2103321View attachment 2103323View attachment 2103322View attachment 2103325
A wild Saturday night in of reprofiling knives tonight. Wanted to get the MagnaCut Native thinned, and figured since I had the stones out it was time to do the 15V Paramilitary 2 while I was at it. Both steels are great to sharpen on diamond abrasives. 15V continues to impress with its sharpenability, especially given its extreme vanadium content and high hardness. MagnaCut works nicely as well and is another favorite steel to sharpen. Both deburr very nicely and want to come up super sharp. Not the cleanest bevels I've ever done, but they will cut.
