Lexan = good stuff. Maschines really nicely and very easily unlike plexiglass. Very tough an pretty strong but most importantly, it is clear colored and can be used for windows. The most important application these days are probably CDs and DVDs which are made (except for the writable interior) from polycarbonate. It is fairly soft and scratches pretty easily but can be coated to produce a harder surface finish. Its most common nemeses (plural of nemesis?) are UV irradiation and aceton. In particular the later will not only dissolve but literally crack it. UV will also decompose it over time. Withstands very cold temperatures (we use it under liquid nitrogen), can be solvent welded like plexiglas. Quite resistant to fairly strong acid (15% sulfuric acid) but will be decomposed by very strong acides like 100% sulfuric. Will become plastic at fairly low temperatures (around 100 deg C if I call correctly).
Just some tidbids that come to mind immediately.
