I live in the Pacific NW so there are a TON of blackberry bushes and scotch broom out here so I want to be able to cut through the thin, lithe vines of blackberry and scotch broom as well as cut through the thick, woody blackberry vines and then do some general camp chopping (splitting large sections of firewood into kindling, cutting fallen branches into more manageable sections, etc.)
Hi, Joe. I'm fairly new to these forums but I also live in the PNW and I do
a lot of blackberry whacking with a machete. I use them to clear property lines and set lot corners in construction. I also do a lot of volunteer habitat restoration work which often involves whacking blackberries. I also do some volunteer trail maintenance work - both organized and on my own. My machetes see a ton of work.
You don't need anything fancy to clear blackberries. Your local hardware store will probably have what you need so long as you have the ability to sharpen it to a razor's edge.
Hardware store machetes will most likely be made in either China or Colombia. You want one made in Colombia. They actually use machetes down there. The steel will be better and the fit & finish will be better. Buy one that feels comfortable in your hand don't be shy about cleaning up or smoothing out the handle with a file (reduces blisters).
If you're working for any length of time with your machete or more importantly working around other people then please be sure to add a wrist strap to your machete. At some point you'll loosen your grip for a moment it the thing will go flying. Don't let it injure yourself, your pet or other people working around you. USE A WRIST STRAP!
When cutting blackberries slice through the stem at a 45° or sharper angle. A 90° angle to the stalk will just bend the stem instead of cutting it. When cutting scotch broom use an even steeper angle. Better yet - if you're trying to get rid of the scotch broom then just pull them with a weed wrench (google it). They pull a lot easier than they chop.
Another member wrote, "A long thin machete is great for swinging all day, but a shorter stout blades are just so tough."
For blackberry and scotch broom whacking you need the long thin blade. Minimum length is 18". I used to have a 14" and it could do some work but it was limited. However it was handy to hang on the belt and made a good trail companion. A friend liked that blade so I gave it to her.
My current users are an 18", a 20" and a 22". None of them are pretty, these are users. The 18" is the one I'll choose for bopping down the trail clearing things as necessary. But for cleaning out a blackberry bramble I choose the 22" every time. As you're working a bramble you're clearing a sphere around yourself as you go. The sphere of a 22" is naturally wider than the sphere of an 18". The blackberries will catch your clothing and flesh less often with the 22".
Speed and sharpness are the two keys to blackberry whacking. Learn to swing fast. A swift blow can take a 1-1/2" alder sapling in a single blow, or take a man's wrist just as easily.
I probably don't need to tell you to wear leather gloves and heavy clothing.
Here are my current users.
