- Nov 24, 1999
I have a Delica 98 that has seen some pretty hard use and is going to be retired from daily use here pretty soon. I'm planning on taking it apart and making a dymond wood handle with 410SS liners for it. And I'll have to do some work on the blade too. Can't decide wether to try and grind away the back of the bevel until I can make it a flat grind. Or if I should just redo the blade with a hand rubbed finish. Its starting to get thick at the edge, but it still takes a good enough edge, and it won't get sharpened as often when I'm not carrying it everyday. Too bad I don't have a grinder I can do hollow grinds with.
Before I get it taken apart, I'd like to know what size the pins are, so I can have them, or at least have them ordered. I'll probably use a screw type pin for the blade, and maybe the locking bar too.Anyone know what size they are?
And just out of curiosity, if theres anyone out there that has taken one apart before, is the backspring molded into the zytel? Just wondering how hard it will be to get apart without damaging the spring.
Thanks for any help.
It'll feel better when it stops hurting.
