Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Hey, I'll buy that 2/0 off you, if you are really looking to gt rid of it. That was the whole point of this thread originally. I can't find one anywhere else, and I'm annoyed because I've been putting off buying a spare for months now, assuming I'd always be able to find such a cheap, common knife somewhere no matter what happened.It is my intention, El Gato!!
Well, I like the red I have, but I'm curious as to the stain!!
How do you knock the blade out? Mine looks like it's got some sort of snap ring or something on the end of the tang holding it on the handle.Another option would be to buy a Mora Wood Carving Jr 73/164. Its easy enough to knock the blade out of the handle, remove the guard and put it all back together
Thanks, I just ordered one. I'll give it a try. I'm curious to see how they hollow the inside of the handle, if it's a round hole and round tang, or both square, or some combination. I've finally ordered a bare blade and carving a handle for it, but I'm not sure I have the means to drill a proper hole. If it's round I can manage, but not if it's square, and I'm not sure a square tang will fit snuggly enough in a round hole.Tape up the blade (always!)
Place in a vice tip down, with a firm but not tight grip on the blade but so the ferrule is on top of the vice
get a cardboard box full of news paper and place inline with the blades travel
make sure nothing but the box is below the blade - get a flat head punch smaller than the snap ring/collar and hammer and give it a few taps
it'll come out
He was replying to my saying I wanted to see how a Mora was assembled, I assume.lost me?
that's a 9 year old blog post
a good one but still ?
Luckily my hands are relatively small, although I only use mine for light tasks and a neck knife. For anything that takes serious cutting it's not big enough; not enough blade, and not enough handle. And of course the scandi grind is best for carving wood. For actually slicing and cutting it is inferior to a flat grind. I find it a lot harder to cut straight. But for carving wood, and by extension, peeling potatoes, it works better than a flat grind. And yes, the sheath is basically worthless. You are more or less just buying a knife, nothing else, but they include the sheath for sales purposes I guess, so they can advertise it as "includes sheath". And it does, if you really can't get a better one.Mora 2/0 are still available here in Australia. I bought a couple recently and have to say I agree with Woodtrekker’s review, I find the handle is just a bit short. Good blade length though. Terrible sheath I don’t trust it one bit.
So in one day I ordered a mora youth carving knife, a 2/0 blade and now a whole 2/0.
Interesting. I noticed that the blades weren't exactly identical, but I thought maybe it was just variances in the grinding process, since it was mostly in the tip shape. I hadn't even noticed that it was thinner; if there is any difference I can't tell by looking at them next to each other, so it's pretty minimal. I basically converted my carver into a 2/0 by removing the guard; they are now functionally identical. Which is good because I'm not sure I actually found a 2/0 or not; I ordered one from a site that advertised them, but I haven't even got an invoice yet or any kind of acknowledgement. So I'm glad I got this one anyway, even if that never arrived.So what are your plans for the youth knife since your flush in the 2/0 department? Also, I found out today via Redbeard that the knives are not as similar as I thought.
"Both of these knives are extremely similar to the eye in size. Blade and
handle are almost the same length. The only major difference other than
what you mentioned is that the JR is not as heavy as the 2/0. The handle
weight is less and the blade thickness is a little less. 2/0 is .098 and
the JR is .080 You can tell the difference in weight but as far as size,
quite similar. I hope this helps coming from someone who has had both in
hand side by side.
Best,
Redbeard"
So here's the new Mora 2/0 blade.
Does anyone know where I can find a retaining ring to fit this? I guess they figure if you're ordering plain blades you have the knowledge and resources to do it yourself. Or can you suggest another way of fixing it into a handle? I've never done this before. I'm sure I could just epoxy it, but I'd rather do it the "old fashioned way".
I was thinking something similar maybe. These do have the notch that could be used to retain the blade; I'm not sure if they are just included to locate the pieces while machining, or if there are models that use them to retain the blades, but it'd work for that. The 2/0 is a little different ffrom other Moras because it's full tang, but I think from the pictures on the package that it's the same as the others other than that, i.e. the semi-circular notch. Probably the tang would have just been too small if they had tried to make it a half tang.Neither of these is a 2/0, but the tang on all the Mora blades is pretty similar. It's probably not the way you want to do it, but maybe it will help you with some ideas.
O.B.
