Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Jeff Clark said:Throwing knives and sharpened crowbars. If you are going to apply a bunch of leverage to the point you need it pretty thick at the spine.
GarageBoy said:Sharpened crowbars-= busse combat, etc
Generic term
When using a knife as a prying tool you don't want it to store energy and rebound like a bow, you want it to be stiff. It is also very inefficient to pry with a knife when it is bent to a large angle, you can no longer readily apply force to the handle.the possum said:...so bending and impact forces are spread over a greater length of the blade.
People who want to cut with them, some people even grind a point and put a handle on them to make them into fairly versatile tools.Rat Finkenstein said:Who sharpens their crowbars?
Cliff Stamp said:When using a knife as a prying tool you don't want it to store energy and rebound like a bow, you want it to be stiff. It is also very inefficient to pry with a knife when it is bent to a large angle, you can no longer readily apply force to the handle.
-Cliff
Rat Finkenstein said:I was unaware that "Generic" has the same meaning as "Idiotic".![]()
Grover_Cephas said:I was unaware that "commonly used by a knowledgeable community" was synonymous with "idiotic".
It's an evocative, generally accepted term for that class of knives that's designed less for cutting and more for not breaking when abused.
It isn't always an attack, some people mean it as an insult, but not everyone does.Rat Finkenstein said:...why attack them?
They are designed primarily for low cost. They would work much better as cutting tools if they had a distal taper and a full hollow grind, they would also be more efficient to sharpen.martin j said:Moras are not prybars and they have no distal taper, I think most people would say the are designed for cuttiing ...
The better ones do. Machetes are again designed to be really cheap to make, a properly ground golok with suitable balance is a much superior tool, however it costs ~10 times as much....most machetes also they have no distal taper but they are not 'prybars '
Yes, a bow just allows more, for some knives this can be a benefit because you want to increase the impacts they can take.the possum said:Even if the blade is so thick you can barely see it flex, it is storing the energy all the same.
The StriderGuys have done pretty well...IMHO!Rat Finkenstein said:Who sharpens their crowbars?![]()
The primary grind, leaving it sabre or going full?Jeff Clark said:I plan on converting it to a convex grind ...
Rat Finkenstein said:Anyone calling hard use knives "sharpened crowbars" is not being "Knowledgeable"- they are merely expressing negative stereotypes and attacking certain makes/models of knife. This crap always seems to crop up when people ask for, or recommend knives made of thick stock- Busse in particular. If you dont like tough knives, dont buy them- but why attack them? What is gained?- only animosity.
I didn't notice this before, but you're right. I have a feeling that I'll be going through all my knives with the calipers later today.the possum said:I can't think of any applications where I'd intentionally not want any distal taper. But, there are plenty of blades where I wouldn't worry about it. Most blades will have a "natural" distal taper just because as the profile narrows towards the point, the grinds will get accordingly thinner. Most smaller knives won't need any more than this.
