- May 28, 2012
and plastic knives outlawed by the state of New York are the worst,.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Lol love how in the second video Lynn is like “New York banning plastic knives to avoid them from being undetected by metal detector is stupid BUT these knives are great for stabbing and puncturing through ribcages, so check them out”.
#lynnlogicLol love how in the second video Lynn is like “New York banning plastic knives to avoid them from being undetected by metal detector is stupid BUT these knives are great for stabbing and puncturing through ribcages, so check them out”.
While you are right overall, the carbon content alone does not make those alloys equal in all performance metrics. For example, although they share similar levels of wear resistance, 420HC is significantly tougher than 4116. In fact, it is among the tougher stainless alloys according to Larrin’s research, roughly in the same ballpark as 14C28N and AEB-L. Whereas 4116 is on the weak side, listed as having a slightly lower toughness than S110V.If you think that 420HC is good, then the 4110, 4116, 4034 and other .5% carbon (X50/5Cr) can't be see bad as cutlery steels. The heat treatment generally decides the final outcome.
Worst steel ever is any of them with a crappy HT !I’m genuinely curious, I’ve heard many people complain about 420 but I own a couple Buck knives and they hold an edge on par with higher end steels.
What’s your opinion?
I respect and use Larrin's site often, but I disagree with him on the 1.4116. He has 1 sample and doesn't cite its origin and heat treatment unlike most of the other example he has. If that one sample got the better property of the steel, then it would have a different views from people.While you are right overall, the carbon content alone does not make those alloys equal in all performance metrics. For example, although they share similar levels of wear resistance, 420HC is significantly tougher than 4116. In fact, it is among the tougher stainless alloys according to Larrin’s research, roughly in the same ballpark as 14C28N and AEB-L. Whereas 4116 is on the weak side, listed as having a slightly lower toughness than S110V.
See this chart by Larrin, one of the most well-regarded metallurgists out there. 4116 is listed at the top, 420HC is four rows down.
Source article:
Knife Steels Rated by a Metallurgist - Toughness, Edge Retention, and Corrosion Resistance - Knife Steel Nerds
Steel Metallurgist Larrin Thomas uses tests of knife steels to rate the steels and explains the factors that control performance.knifesteelnerds.com
A thread discussing the subject:
420hc Toughness
Hey all – recently I posted a thread in the general section asking how tuff 420hc is in general. That thread got shut down (I believe because some people were giving somebody who posted a generic steel chart a hard time) shortly after the thread was started. Regardless I would like to continue...www.bladeforums.com
I love 1018. Not for blades obviously, but nothing gets blacker with bluing for handle parts.Why 1018 of course!
Though... with an awesome heat treat... it is still c**p
Pete at Cedric & Ada agrees with you. See "Ranking Every Pocket Knife Steel I Have Used" on Youtube, Jan 14, 2023.Any time I see something that's listed as "surgical" or "stainless steel", I'm out.
I'm very sure that banning plastic knives will save NY from their epidemic crime waves !Lol love how in the second video Lynn is like “New York banning plastic knives to avoid them from being undetected by metal detector is stupid BUT these knives are great for stabbing and puncturing through ribcages, so check them out”.
I doubt very much that Gerber heat treats their knives made in China with a Chinese steel. I am sure it is heat treated in China by whoever the factory uses.Gerber 7cr17mov. Theoretically, 7cr17mov shouldn't be terrible but Gerber heat treats it so soft the edge will literally dull test cutting paper. That's the main problem with companies selling knives in less than 8cr13mov/AUS 8, nobody who actually knows anything about knives actually buys anything lower end than that so the companies using it have no incentive to do anything other than grind out a knife-shaped object and make it look pretty. I'd love to see one Rockwell tested, I'd be surprised if it was even 50HRC and that's being generous.
8crmov13 or whatever it’s called. Has to be sharpened after cutting one box, you can sharpen it with a denim pant leg though.
Amen, few people today know the pain of trying to sharpen the 80's Pakistani boot knife, you know the one that the wooden handle that wiggled like a loose tooth and had the shiny mystery metal that looked like it was made from recycled toasters. It will really make you appreciate 420HCWorst steel ever? What ever the steel was in the Pakistani lock back knife (Buck 110 clone) that I owned back in the early 80”s when I was in high school. It was so soft you could literally bend the blade to 90 degrees and back straight and it would not snap.
5Cr15 ... CRKT
