Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I like this thread :thumbup: I guess you must have spent much time in hunting so that you need a top user hunter. Any picture of your hunting trips? I like threads about hunting knife in action. IIANM JParanee have couples of threads showing and telling about his hunting trips :thumbup:.. I am more interested in taking a look at the best custom fixed blade hunting knives available today not as a collector but to use as a hunter. I am interested in The Using Knives not The Beauty Queens ..
.. I have owned/still do own some knives crafted by the following masters:
Charles May
Gene Ingram
Bob Dozier
Mike Starling ..
check out Horton Knives in the makers section right here on bladeforums.
He is Tier One in my own humble
To decide who the best maker is for a hunting knife you intend to use personally, I suggest you first define for yourself what you want a hunting knife to do. A knife for dressing birds and small game doesnt necessarily fill the bill for deer. A knife adequate for field-dressing deer wont necessarily take care of boning out/butchering an elk or moose efficiently.
If youre in a backpacking scenario, hunting potentially hundreds of square miles of steep forested mountains, you may need to be able to do camp chores such as splitting wood or digging a fire pit as well as fine work such as preparing food or caping out a trophy. You may need to be able to rely on your knife in a survival situation, and know its not going to break, crack or chip out catastrophically. You may need to bone out large animals such as elk or moose to pack the meat out on your back, and need some length of blade to do that efficiently. You may need to split the thick pelvic bone on a large animal to let the carcass cool out. In this case, the choice of steel for the best balance of strength and toughness, heat treated for a balance of hardness and toughness, the thickness of the blade for pry strength and the thickness of the edge for the best balance of durability and cutting efficiency are all critical choices.
On the other hand, a hunting knife for many means a blade that will only be called on to perform field-dressing chores on deer and small game, leaving the actual butchering until you get the carcass home where it can be worked on with kitchen knives or dropped off at a wild-game processor who will butcher and package the meat for you. In this case, a 3-4 blade hunter, fixed or folding, will do the job without fanfare. In this scenario, if edge holding and a highly-efficient cutting edge are of paramount appeal, you may decide to go with an uber-wear-resistant stainless steel such as one of the CPM stainless steels in a nice, thin blade. On the other hand, the lower toughness inherent to CPM stainless alloys may not be acceptable in a survival situation, in which case you may be better served by a little thicker blade and edge made of good spring steel with expert heat treatment.
Study and decide what your requirements are for:
1) Steel and heat treatment: strength, edge holding and stain resistance vs. toughness, durability and resistance to catastrophic failure.
2) Geometrycutting vs durability. Thin, hard edges = best cutting/best edge holding, but not the best for going through heavy joints and bone, if thats an issue. A small-game hunting knife can have a very thin, hard edge that will last and last. A large hunter that will be called upon to split a pelvic bone on a moose may need to be thicker at the edge. Steel can mitigate the vulnerability and enhance edge holding, but striking the right balance is key.
3) Blade style is specific to the hunting task and to personal taste. Many like a skinning style blade with a trailing point. Others prefer a drop point, as having an upswept skinner-style point in many applications is more awkward. For example, an upswept point that rises above the line of the spine becomes awkward when the knife is turned upside down to make a gutting cut because the upswept point is now sweeping downward to bite things below your fingers which you cannot see.
4) Ergonomics. Hand size and specific hunting applications and tasks vary as do personal tastes. Some prefer grippy man-made materials such as rubber or Resiprene or textured micarta. Others may prefer smooth natural materials like wood or bone, with contouring that provides security, control and comfort.
Once you decide what tasks your hunting knife must perform well, and what steel/heat treatment/geometry/blade shape/size options you will require, take a look at ergonomics and handle materials. Then you will be able to begin looking at the work of individual makers whose work is to your tastes in the areas mentioned, to find the right maker for you. Perhaps you will want to begin saving some photos off the internet of knives that come closest to satisfying your preferences.
Makers offer design, materials and the craftsmanship to put them together. You have to decide what best hunter means for you, and then you can begin the search to find the best maker for you.
Finally, you may find, as I have, that the styles of some of the most expensive hunting knives to be found are essentially worthless for your needs. You also may find that performance-wise, some of the most storied master smiths produce knives that are, in fact, weak and substandard in fulfilling your requirements in the field. Some will tell you that damascus steels out-perform single-alloy steels or that forged blades out-perform blades made by the stock-removal method. These claims are typically half-truths. Dont believe the hype on the surface. This kind of knowledge comes from extensive reading and experience in the field. Read what others have experienced for themselves on these forums and elsewhere, and decide for yourself what the truth is for you.
