Drew Riley
- Oct 17, 2007
So I'm not supposed to put my tongue on the wire to see if it has power? It works for a 9-volt battery!![]()
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
What kind of meter do you have? Most cheaper meters will prefer sinusoidal waves when reading AC voltage, but unfortunately, a VFD puts out something closer to square wave, so unless you have a meter with a LP filter, you probably won't get much more than gobbledygook. In this case, A continuity check would be more telling.
Check continuity from your hot leads to your motor housing (U, then V, then W) and also check continuity to ground.
Could be as simple as a fractured wire insulation, or a loose wire nut, though I'm surprised the VFD isn't faulting out. Are you sure all of your ground wires are connected? Is there continuity from ground to your motor housing? Is it just the motor housing that's giving you a shock? Or is the VFD housing? Or the grinder frame itself?
As mentioned above, There should be a grounding conductor but I suspect its absent. Appliance should never been put into service without. None the less, If the appliance is not grounded, thats not a root cause for electric shock anyway.Is there a ground from motor to VFD?
I hope you meant to write ”3 hots and a ground” !!motor has only three connection lugs (220v 3 phase, two hots and a ground, just like my welding machines), they are all connected securely. I don't understand where the fourth wire is supposed to be. Would that just be from the motor frame to the VFD frame?
I dont remember ever seeing ”Ground” on a motor being a wire lead. Its always made as a connection somewhere to the motors metallic frame.
Using only 3 wires to your motor, I can envision a couple incorrect wiring scenarios what could create shock hazard on regular threephase, But surprised if thru a VFD could run it without at least some kind of faultcode.
You might again study your VFD instruction manual knowing your motor needs 3 HOTS & A GROUND !
