BMK
BANNED
- Jan 30, 2011
A question only a fully committed neophyte like me could ask:
Why do many knife makers grind a secondary or micro-bevel as opposed to ginding a single angle or curve as in the case of a Scandi or full convex bevel?
Every time you resharpen a micro-bevel or secondary edge, blade geometry changes. With the Scandi and full convex bevel, edge geometry remains constant through sharpening cycles.
I have not seen the numbers but I bet there is less friction when separating material if there is no secondary edge or micro-bevel. If someone has access to these numbers, I would like to see them.
If material separation is what a knife is designed to do, then why use secondary and micro-bevels?
Thanks for your ideas. Fire away!
