I think it’s more like some late hits that keep coming after the sack, but I’d prefer to think of it as altruistic, too.Boy, you guys are making a huge effort to help a guy who thinks this forum is garbage. Bless all of you.
And yet you've wasted your time, and the time of many others who tried to help you, when you didn't really want help.I value my time to an extreme degree that most do not or cannot understand.
What do you use your knives to do and how do you use them? Just cutting string and cardboard or field dressing game etc? Depending on the answer, a pull through sharpener may be the exact thing you need.I've recently noticed a lot of disdain for and ridicule of those using what I see called pull sharpeners. I've gathered that this means any type of sharpener in which you literally pull your knife through a slender opening with some kind of rods in the shape of a V at the bottom.
Honestly that's all I've ever used. They get it what I would call "working edge sharp" and I've been fine with that. I have noticed that they remove quite a bit of material. Is this the reason nobody likes them? Or maybe its the rather obtuse angle at which the rods force the edge to be?
I'll be the first to admit I don't do high maintenance anything. I would prefer to use the best products and apply the best practices in everything I do, but not at the sacrifice of it being higher maintenance to any noteworthy degree.
A long time ago I purchased a couple different highly touted sharpening systems. One a Lansky that requires way more set up and time than I'm ever interested in. The other is, I think, a Spyderco something or other with varying rods that go into various holes in a plastic base that you then stroke your knife through several times on each side. It came with a CD on angles and techniques etc. That one doesn't seem so bad, but I tried it once and felt like it didn't do anything and doing the angle right is all in how you hold it which is a huge margin for error. So i went back to the pull through type. I've got a dozen of them, they all work and get an edge that I've thus far found acceptable.
What's your take and thoughts?
He ain't got time for dat!He would probably be better off looking for a hardware store that has one of the new robotic sharpeners.
How do you feel about one man arguing against all of the internet, and quite possibly himself?What's up guys, what'd I miss?
Link??I think I found the perfect sharpener for JayDeep for only £3,200.00 +VAT. There is a cheaper model for home use for £699.00 +VAT.
CATRA I-100 Commercial Knife Sharpener
One of the world’s best commercial knife sharpeners gives you all these advantages:
The I-100 operates using the Spiral Interlock Grinding Wheel system known throughout the world of knife manufacturing and sharpening, and one that CATRA has been using for over 40 years. By coupling this system with the high-tech abrasive Cubic Boron Nitride (CBN), it provides CATRA knife sharpeners with many advantages.
- Less than 10 seconds per knife.
- No skill or lengthy training required.
- Consistent edge angles on every knife, for every user.
- Safe and comfortable to use.
- Does not need water, since our CBN abrasive wheels gives a cool grind.
- Compact, with a folding side-handle for ease of transport.
- No adjustment necessary.
- Low consumable cost, as grinding wheels can be recoated, typically £0.01 per blade sharpened (<$0.02).
- Stainless steel covers and water resistant electrical equipment.
- Sharpening angles of between 30° and 60° are available.
- Operates from 240 or 110 volt electrical supply, or even a generator or 12v inverter.
- Available with range of abrasive grit sizes, for different knife uses.
- Ideal for abattoirs, fish and food processors, knife sharpening services, small knife manufacturers and other related industries.
- Suitable for sharpening up to 1000 knives per day!
- Magnetic dust entrapment system prevents contamination of food process areas.
- Capable of sharpening both single and double bevel blades.
By selecting a particular sharpening angle, typically 30°, you will consistently produce high levels of sharpness, as the edge angle is controlled by the grinding wheel diameter. This diameter does not change during the life of the CBN abrasive.
Each pair of interlocking wheels is capable of sharpening a blade at least 20,000 times and much more if a knife blade edge thinning system is operated. When the time eventually comes around, wheels can be returned to our Sheffield workshop for abrasive recoating, thereby keeping consumable costs low.
Different grades of abrasive are available, which allow knives to be sharpened for different applications.
To quote the moderator: PLEASE - no links to sales sites or advertisement. - ModeratorLink??
Basically, a guy asked a legit question about his sharpening method, didn’t like the responses.What's up guys, what'd I miss?
I see on their webpage that the sharpener is suitable for:I think I found the perfect sharpener for JayDeep for only £3,200.00 +VAT. There is a cheaper model for home use for £699.00 +VAT.
If you check his other posts it’s obvious he’s a troll.Boy, you guys are making a huge effort to help a guy who thinks this forum is garbage. Bless all of you.
Yup, I hit "ignore"If you check his other posts it’s obvious he’s a troll.
1: Burrs. An edge with a burr or wire edge seems sharp until it breaks off. Have to remove the burr. I didn't read about your sharpening method.Why did I need to run my knives through the sharpener after each use to keep them sharp?
but the guys doing it are pros, and many warn that it's harder than they make it look. The internet is full of confusing, contradictory information on the subject.
