The reason that I will not warranty a stainless blade is due to the simple fact that I cannot make the material perform to the level of my forged blades. This came about because I had/have a very good customer who begged me, until I agreed to make him a knife with S30V. I spent a huge amount of time and effort, trying to engender the same qualities that my forged blades posses, and I did warranty that one.....after one hunting season the individual asked me if he could return that knife, and have me replace it with a similar blade of forged 52100. When I asked what he didn't like about the so S30 blade, his reply was.....everything. His main complaint was "I just can't sharpen this thing." When I got it back, there were a few tiny chips along the thinnest cross section of the edge, and by the time I tempering it to the point that chipping did not occur, it was too soft....basically the only way to deter the chipping, while keeping the blade hard enough to be functional, was to increase the edge geometry, which greatly increased the cutting resistance....which goes back to the blade seeming dull when in use, even though it was as sharp as I could get it with that given edge geometry.
Of course I don't know it all, and there possibly could have been some things I could have done differently with that blade/steel, but I spent nearly two months experimenting with that steel, and consulting with others who know much more about S30 than I do. All of the inputs told me that the steel simply would not tolerate the very fine edge geometries I use on my forged blades.
Concerning the geometry/Maker connection.... We have to go back in time when a certain production knife company introduced a particular knife that used 440C for the blade. The "engineers" who recommended the use of 440C read the technical properties and determined that the blade should be produced at a an Rc 61, which is what was done. Initially the blade of that specific model was flat ground, however, at Rc 61, the edges were too brittle to be durable. Rather than rethink the hardness level or blade material, the company changed the grind as a compensitory measure to increase the strength of the edge......this was when the "hollow grind" was perverted into what many of us call a "semi-hollow grind", which thickened the edges considerable, and at the same time created a much more obtuse cutting edge geometry......making that knife cut poorly, and very difficult for the average owner to sharpen. This all occurred while the custom knife movement in the country was in its infancy, and since that particular grind was somewhat easy to achieve, many early custom makers who practiced stock removal adopted it. It has endured to this day, not because of anything about it being better or superior, but because it was fairly simple to learn, and it countered the issue of thinner edge cross sections chipping at a higher Rc level.
SOME makers, who utilize stainless have taken the time and effort to test, and have made minor adaptations, but are still limited to what they can do with edge geometry, because of the limitations of the material. You simply cannot seperate the fact that along with high hardness, comes brittlness...and many of the stainless steels have a very narrow window between being too hard or too soft to function in thinner cross sections, such as a blade edge...generally it winds up that a compromise becomes necessary, and in most cases that compromise is detremental in some way to the blade's function.
I know I'm stepping on a lot of toes here, but again, its not meant to be anything malicious, just trying to honestly answer a question based on my observations and experimentation.
