Medic1210
I'm not talking about the videos the manufacturers made to sell their system, I'm talking about user-submitted reviews and videos of either the system being used or more importantly- images and cutting tests of the resulting blade edge. You and others in this thread have purchased the system so I was hoping someone would demonstrate how it performs. This isn't a malicious request- I'm genuinely curious about, for instance, what grit begins to produce what cutting effect. What do the bevels look like for a variety of blades? If you've already purchased the W.E., would you recommend buying the strops for it right off the bat as I assume they're needed for the finest edge possible?
E.P./W.E. bevel increase
For the E.P. I believe this is only applicable for knives where the blade is thicker near the tip-bevel than the rest of the knife. Used properly, the E.P. will have no problem putting a
perfect bevel on the curved portion of a uniform ground blade- Ankerson's images demonstrate that with the Spydercos. The W.E. will have the same problem with blades that are thicker at the tip, but the effect will be
compounded by the design of the system.
Explanation:
Sometimes, if one wishes to convince themselves an effect is real you have to imagine an impossible scenario (bear with me here
). Imagine a blade one mile long clamped to the W.E. with a one mile long guide-rod to match. Moving out near the tip the stone and guide-rod are practically parallel with the blade and the bevel in effect
is the blade. That would also mean the resulting edge is being sharpened at a very tiny inclusive angle.
Throw that scenario away and imagine a normal long-bladed knife in the W.E. The bevel will still increase near the tip and the inclusive angle will be smaller, but as someone already mentioned the effect isn't very large. But that's still a counterpoint to
clayallison's claim that the angle and bevel remain unchanged for straight-edged knives out to any distance.
I'm still trying to imagine the curved-blade effect on the bevel and angle. Does that mean if you sharpen a long blade with a thick curved tip the resulting bevel will be widened by three different factors?
Maybe that's the ultimate nemesis of the W.E. system- a long bendy FFG blade with a thick curved tip. The resulting blade would look like it was sharpened by a highly caffeinated funhouse clown
