This weekend I picked a piece of ironwood, outlined the tang and drilled/milled/carved out the slot.
And then a quick trip to the grinder to create the rough profile.
Bonus points: the tang does not peek through the bottom of the handleMentioning that for NO REASON whatsoever, never could have happened to me.
And then today I did a basic layout on the handle, and roughed out the shape - still lots of meat to be removed. I am going for coke bottle shape if that was not obvious.
I postponed drilling the crosspin hole so much that I will have to do it now with the handle already being shaped, so I will have to reference the ricasso, but no big deal.
I also started to roughly shape the guard (I have a very sketchy setup to grind the bottom inside curve that you will never see). I will be making a simple mounting rod/handle so that I can access the guard better for further shaping and finishing, I wanted to do that couple of times already but better late than never. That will be the next update I suppose.
I only have a small update, I finally made the tool for holding the guard for finishing. It is like a machinist parallel clamp, but it clamps on the outside. Not sure how well the brass screws will hold up, but I can make new ones. It holds the guard well enough for filing and of course sanding.
