it's time to start drilling and tapping some fastener holes. I thought I was being clever by shielding the lines with tape, but the juice wasn't really worth the squeeze.
this is a scale fastener hole. It'll be a 5mm x .8 because I'm going to use bicycle rotor mount bolts, and metric is how we do up here in Canada.
holes drilled and surfaces flattened again. It's so important to remove the bulging caused by drilling, because it can cause subsequent holes to be less than straight
the backspacer fastener holes are going to be a 3mm .5 thread, also using fasteners scavenged from a bike. In this case, stainless fasteners for holding a dereilleur hanger to a mountain bike
a side note; if you are going to drill titanium, make sure at least one of these two things is true-
1. have lots of fresh bits on hand in the size you need
2. you want to learn how to sharpen drill bits
nice, clean holes...
I chuck the tap in the drill press and manually turn the chuck, while...
...I apply compression using the height adjuster on the drill press. Compress, turn chuck 1/6 of a turn, lock height adjust down, repeat...
I just start cutting the threads this way because it's perfectly in line, but I finish with the hand tool. Having straight threads to get started really helps
titanium is thirsty metal. Although I don't generally use cutting oil when drilling, for tapping it's a must. It's very slow going with titanium, it tends to gall, so breaking taps is a real issue especially smaller ones. Just gotta develop a feel for it
