Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Mechanically it would be a simple addition of a few lines of code to machine the holes and pockets for the inserts in both scales. Aesthetically you would see the unused three brass inserts. Absolutely doable though.
Boomer52, these look fantastic. Where can I find a way to order a set?OK... it took longer than anticipated to machine another set of tip up Military scales. We had an historic amount of snow... broke records for February going back to 1919...! Clearing snow and frequent power outages kept me out of the shop.
Additionally the Military I was machining for was an older back spacer model that isn't quite the same as the newest model so it needed a complete workup in CAD/CAM which takes time. I now have files for both models.
Anyway... I modified the machining code for the press in threaded insert pockets and holes to correctly install them from the outside surface. The use of the mini drill press arbor to install the inserts was not a success. I experienced too much flex and abandoned the idea after destroying the first insert during the attempt. I ended up using a pair of vice grips which when applied carefully did the job.
I used coarse peel ply black G10 and all hardware was replaced with button head hex stainless with the exception of the pivot D-bolt.
The Lynch Deep Carry Ti pocket clip in the last photo is the shorty version... I did not have a long clip on hand...
Here's some pics...
Interested!! Both materials sound great, and I would love to see the final product.Unfortunately I no longer machine custom Military scales per order.
I have one threaded backing plate I reserved which I will use for the full contour scales I plan to do for a CPM S30V bladed knife and offer up as a spec sale when finished. Haven't selected the material I will us as yet. Vacillating between LVA carbon fiber or burlap Micarta and ivory G10 liners. I have the 3D modeling finished up... just need to find some time and get the CAM side code written.
Nice! Do you plan to crank these out for the forum members?
