- Oct 3, 2011
So I just bought myself a Victorinox Soldier 2008 version (2015 as per the tang stamp) and I'm pretty much satisfied with it. Bought it from our local physical knife store and the tools are amazing as always. In addition, the entire knife feels very sturdy, the blades don't hit the liners and everything seems perfect.
Unfortunately, the day after I bought the SAK, I noticed that looking at the knife from the backsprings, there appears to be a gap between the scales/liner and the first backspring. I didn't notice this when I bought the knife because it felt sturdy and the scales were firmly and completely in place and without any gaps between the nylon and the outer liner. However, this gap seems so apparent to me now, and I'm really bothered. See for yourself:
free picture hosting
The backspring appear to be thinner than base of the tool it is supporting hence the gap appears. However, when I try to press the scales together there is very negligible movement because the hinges appear to be very solid and are completely attached to the scales.
Here's another pic with the can opener tool out:
image hosting 30 mb
See the bright part where you can see the light seeping through is the gap while the dark areas on both ends are already the pins that hold the knife and the tools together.
One last pic looking at it a bit from the bottom end of the knife. You see the top part of the backspring is totally not touching the liner with the scale, except where the hinges are:
image hosting
Question is... should I be worried that this is shoddy construction? Is this normal in other Victorinox Solder OH's? I ask because my slide lock Hunter doesn't have this gap issue.
Thank you.
image hosting 30 mb
image hosting
Thank you.
