XH1215 or XH1220 1095 hgh-icarbon steel
So the XH1215 and XH1220 is throwing me off when I'm about to buy bar stock for my first blade. I just made a blade yesterday that ended up really well, until I found out that low-carbon steel can't really be hardened for good blade making. If i shouldn't use 1095 what should I use? I want something tough that will hold an edge well, something for a utility type knife. Thanks for the help!
I have an abundance of 1215 steel scrap from the shop I work at. Is it good for knives?
I think 1215 is a free machining mild steel, not good for knives. I’ll look it up and report back.
Hoss
Welcome to Shop Talk.
Fill out your profile so we know where you live and something about you.
1215 won't work at all for a knife. it has .1% carbon. It is a low carbon machining steel.
You mentioned 1095. That is a good knife steel. 1% carbon.
Are you forging? Are you doing stock removal? If you’re doing stock removal there are a ton of steels way better than 1095 or 1084 that you could choose from. Just depends on what methods you’re using.
1215 has .09% carbon content, and very low manganese. It is close to the carbon content of wrought iron (.05%).
It isn't a blade steel.
The lowest carbon content blade steel normally used by knifemakers is .60% carbon (5160).
By "MIXING", if you mean layering it and getting a homogenous higher carbon final content, it really doesn't work that way. Carbon migration happens but it isn't like adding things in a kitchen recipe.
You would need to stack a 1.25" thick bar of 1095 to every 1/4" bar of 1215, forge weld it, and fold it a good 10 times to even get a 1080ish final result (which you would not actually get). ..... Math - [ .09+(5x.95)/6=.80 ]
Obviously, you would be far better to make knives from the plain 1095 and leave out the 1215.
The best choice of mixing would be to use it for san-mai. A cladding of 1/8" 1215 - 1/4" 15N20 - 1/8" 1215 would forge out to a nice san-mai billet with a bright and hard sharpenable edge and soft dark sides. This is similar to what many Scandanavian blades are made from.
An equal damascus mix of 15N20 and 1215 would make a high contrast billet that would be good for hardware such as guards and butt caps. It would not work as a blade material. It is decorative but would have poor edge durability. About 50-100 layers would look good.
You could combine those two uses of your 1215 and make an equal damascus billet of 1215/15N20 and use it as the cladding on a san-mai with 15N20 as the core. This looks quite stunning. I used to do it with 203E/1080 damascus cladding and 52100 core.
