With the Xiaomi Chuangmi CMSXJ01C 720P IP camera, you can sleep soundly and won't worry about your home when you are out. The built-in 6pcs 850nm IR-cut LEDs enable this surveillance camera capture clear night vision images up to 9 meters distance. What is more, the concealed TF card slot provides not only a beautiful and integrated appearance but also a convenient storage method for you.
Product Features:
● Keep recording 1280 × 720P HD videos, never miss any detail.
● 120-degree wide viewing angle FOV, detect wide area.
● Built-in microphone and speaker, support real-time two-way communication.
● Insert a micro SD memory card to store video for viewing at any time.
● Connect with internet via WiFi, realize 10m remote control.
● Support remotely monitor by using smartphones, tablets, PC or TV.
● Support above Android 4.4 and iOS 8.0 version devices.
● Built 6 pieces of 850nm IR LEDs, the biggest night vision distance is up to 9m.
● Motion detection, up to 9m distance.
● Partition hierarchical detection, reduce the nuisance alarms.
● Motion sensor works with APP to achieve remote monitor, know what you want to know by smartphone at anytime or anywhere.
● Floating window of APP suspends on the top of phone, convenient for watching.
● Turn on the sleep mode or set sleep time in the APP to enter the standby mode, effectively protect your privacy.
This camera only weighs 65g, and there is double sided tape to fix, so it is very convenient to install. The horizontal direction can be rotated 360°, and the vertical direction can be rotated by 100°, fixed it in one place, you can see the whole home: https://gearvita.com/xiaomi-chuangmi-cmsxj01c-720p-smart-ip-camera.html
Other hot sale products from Xiaomi:
xiaomi mi box s global version
aqara gateway
Product Features:
aqara gateway
