Xiaomi Cleanfly FVQ car vacuum cleaner is small and portable, handheld wireless, ready to use, more than 60% smaller than the traditional car vacuum cleaner, so it can be stored in any corner of the car. The car vacuum cleaner adopts 65db low noise and 5.0KPA suction design for comfortable usage, safe current fuse to avoid the damage of power supply, as well as HEPA filter and layer cloth bag filter which to avoid the dust seepage. Leak-proof shield prevents trash from leaking out, it will close automatically when the vacuum stop working, and open automatically when vacuum start.
Product Features:
● Small and Portable
Can be put in storage box, cup slot and pocket of your car and save much space.
● Strong Suction
Pressurize with multi-level cyclone air flow and designed by spiral fan blade, suction up to 5000Pa and rotate speed up to 32000rpm, collect paper, dust, hair and coin easily.
● Wireless Handheld
Say goodbye to cable and twining wire, easy to use, clean any corner deeply of your car.
● Fast Charging
Supported by 12V/2A fast charging tech, can be fully charged within 1.5 hours, allow for 13mins working.
● Comfortable Hand Feeling
Two high-performance power batteries are designed ingeniously inside the handle, the center of gravity is rear-mounted to provide a comfortable grip.
● LED Light with Wide Angle
Equipped with LED lighting, large angle irradiation, easily deal with the problem of insufficient light and complicated environment, provide bright light in the cleaning area.
● Adjustable 2-in-1 Suction Nozzle
Flat mouth, stretch brush design, switch to different state in one second. Flat mouth deep cleaning of the car small gap, brush head cleaning stubborn dirt on the car.
● Patented Ventilation Design
The innovative air guide structure will blow out the internal airflow like the oblique back and sides, so as not to blow dust on the ground and your hands.
The appearance of the Xiaomi Cleanfly FVQ wireless handheld vacuum cleaner is quite pleasant, it has simple design with mainly black color and the dust barrel is designed to be semitransparent black, which is convenient for you to observe whether the dust inside needs to be cleaned: https://gearvita.com/xiaomi-cleanfly-fvq-car-portable-vacuum-cleaner.html
Other good products from Xiaomi:
xiaomi mijia quartz smartwatch
xiaomi mi max 3 4g smartphone
Product Features:
● Strong Suction
● Wireless Handheld
● Fast Charging
