Xiaomi Huami Amazfit 2S Smartwatch - Sports And Business
Feedback: +0 / =0 / -0
Xiaomi Huami Amazfit 2S smartwatch uses sapphire glass material changer and 2.5D curved glass design, while the bezel is made of ceramic material, which is not only beautiful, but also has anti-scratch function. There are three buttons on the side of the watch, can replace the function of the touch screen. This function can be used while swimming, because the watch supports 50 meters waterproof. In terms of function, Amazfit 2S adopts Sony 28nm low-power GPS chip to support 11 sports mode. It is worth mentioning that the swimming mode, it can record swimming data, but also identify professional data such as swimming. The whole process is turned on GPS mode, battery life can be up to 35 hours, it is easy to support 100km cross-country races. In daily use, you can also achieve 5 days of battery life.
Product Features:
● 2.5D Capacitive Touch Screen
2.5D sapphire crystal screen with HD resolution 320 × 300 pixel, protected by Corning Gorilla glass material, high quality.
● Reflective Display Technology
The dial is always bright without black screen. Uses reflective display technology, the dial brightness will auto adjust according to the environment, gives you better and more clear eye experience.
● Ceramic Bezel
Hand polished polished ceramic bezel reflects the charming luster, the excellent hardness of the ceramic can also protect it from scratch lastingly.
● 316L Stainless Steel Physical Buttons
With the stainless steel buttons make you more convenient to control,the case used 3D laser carbon fiber texture, make the feeling of watch texture better.
● Multiple Sports Modes
There are currently 11 sports modes, in addition to the sports that are common in daily life - running, walking, outdoor riding, swimming pool, swimming, open water swimming, indoor running, indoor riding, elliptical machines, mountaineering, also many challenging projects such as trail running and triathlon.
● 5ATM Waterproof
50 meters water resistant, equivalent to water pressure of 50 meters underwater, not only to wear swimming, you can also record the data when swimming, and support open water and swimming pool two modes.
● GPS + Glonass
Can precisely record your daily movement, mileage, altitude, stride frequency, pace and other professional sports data, help you analyze and improve your sports level.
● Firstbeat Health Data Tracker
Show the core data and promptly remind when you are exercise,after completing the sports of exercise,it will use the firstbeat exercise algorithm to give you a physical exercise datas accroding to your amount of exercise: maximum oxygen uptake(VO2max), exercise load(TD), exercise effect(TE) and recovery time.
● Long Time Standby for 5 Days
Ultra-long standby time up to 5 days in the ordinary situation, save the frequent charging trouble. If use the full GPS movement mode, the continuous use of time can reach 35 hours, it totally can complete a hundred kilometers cross-country race.
● Online Pay
Support online pay and music, open your QR code and scanned rapidly, make your life more convenient.
● Phone-free Music
Connect wirelessly to Bluetooth earbuds, enjoy music and media with the internal storage for unencumbered phone-free running.
● Multiple Custom Dials
Built-in multiple custom dials, just need to easily switch between watches or APPs.
● Smartwatch APP
With the new Amazfit V2.0 or Mi Fit, you can connect the app wih the smartwatch, sync data and can look over activity data and exercise in the daily life, update all the data to your smartphone.
Even as an everyday clock, the Amazfit 2S makes a good figure, it cleverly combines a sporty and elegant watch design: https://gearvita.com/xiaomi-amazfit-2s-bluetooth-sports-smartwatch-global-version.html
Related products:
cheap huami amazfit 2 stratos
cheap huami amazfit verge smartwatch
OnePlus Bullets 2T earphones continues the design adopted by the first generation of bullets earphones. The main body of the earphone is made of metal and is sprayed with 205 zircon sand. It is anodized twice to make sure that the earphones have a better texture. The wire makes less easy to knot and wrap and has a wire control function. Aramid fiber is also added to the wire to make it more durable. OnePlus Bullets 2T Earphones has a built-in independent DAC digital decoder, which supports 96KHz/24Bit high-definition audio format, can provide better quality sound from its aluminum alloy sound cavity. The most important thing is that a OnePlus Bullets 2T uses a Type-C interface instead of the traditional 3.5mm headphone jack.
Product Features:
● Crafted a listening experience that's immersive, vibrant, and extraordinarily detailed, thanks to an advanced internal DAC with high-res audio support.
● Fitted with a high-quality film diaphragm that makes voices sound more realistic and immediate.
● The flat-wire cables are tangle-free and threaded with tough Karbon fiber.
● No need to take out your phone every time you want to pause a song or answer a call, that's what the three-button in-line remote control is for.
● The left and right channels reproduce sound independently, reducing noise and capturing each note perfectly.
● By removing the MIC signal from the channels, the quality of your phone calls is significantly improved.
● Traits like temperature resistance and plug durability are all put to the test, and only the earbuds that emerge from the tests in pristine condition are good enough for your ears.
● Perfectly compatible with OnePlus 6T.
The Bullets 2T are extra-lightweight at just 1.8 grams, they're made with an aluminum alloy sound chamber, which does not have any negative sides while greatly reducing cavity resonance which causes distortion of sound: https://gearvita.com/oneplus-bullets-2t-type-c-wired-earphones.html
You may also like:
cheap qcy t1c mini wireless earphones
cheap huawei CP60 wireless charger
Rapoo MT700 mechanical keyboard provides a smart switch among Bluetooth 3.0, 4.0 and wired mode, with the stable wireless transmission. It is compatible with Windows and Mac, can simultaneously connects to up to 4 devices and easily switches between them. Thanks to the built-in eco-friendly lithium battery, you can enjoy long battery life with a full charge, eliminate the need for often replacing batteries. With portable design, the keyboard provides you convenience at home, at work or on the go.
Product Features:
● Slim and Lightweight Switches
Without sacrificing comfortable typing, tested to 60 million keystrokes, these switches guarantee incredible durability and precision.
● Compatible with Windows and Mac
Gives you quick access to media player, volume adjustment, web page browsing and etc.
● Bluetooth 3.0, 4.0 and Wired mode
With stable wireless transmission, you can still use your keyboard regardless of USB port shortage.
● Eco-friendly Rechargeable Battery
Enjoy long battery life with a full charge, eliminates the need for often replacing batteries.
● Non-conflict Design for All Keys
Press any number of keys simultaneously, ensuring every command is registered and executed exactly and rapidly.
● Spill-resistant Design
Do not have to worry about the keyboard malfunctioning after accidental spills.
● Multiple Lighting Effects
A variety of lighting effects suit your personal preference, adjustable LED backlight brightness makes fighting weapon cooler.
● Intelligently Switch among Multiple Devices
Simultaneously connects to up to 4 devices, and switches among them with ease. It simplifies complicated cross-platform use and meets multi-tasking requirements.
Anti-ghosting design with 104 keys, lets you perfectly execute up to 104 commands at the same time, every time. ABS dual-color keycap, not easy to fade, durable to use. Ergonomic arc and slope design, gives you the most comfortable hand feeling and reduces fatigue: https://gearvita.com/rapoo-mt700-multi-model-backlit-mechanical-keyboard.html
You may also like:
cheap xiaomi qi standard wireless fast charger
cheap miiiw mwbk01 wireless bluetooth keyboard
