Lofree wireless mouse is inspired by the retro model, but with built-in touch gesture control that is compatible with Windows and Mac, so you can get rid of the limitations of the touchpad and the trouble of pressing the keyboard. With the latest PixArt optical sensor from Maus, this mouse can work on any surface, such as metal, wood tables, granite floors and even soft pillows. It provides you with a choice of wireless connections, both using Bluetooth and 2.4G, and comes in a customizable DPI level - 800/1200/1600/2400/3600 DPI, which is perfect for working or playing games.
Product Features:
● Smooth rounded shape of the body, high-precision ergonomically calculated weight, reduces palm misting, comfortable in the hand.
● The function of gestures running on Windows 10 and MacOS significantly simplifies and speeds up work.
● With Nordic Bluetooth chip and a 2.4GHz USB receiver, can be connected to the computer via 2.4GHz or Bluetooth.
● Support for different operating systems, can be used on Windows computers, as well as MacBooks, iMacs and others.
● 5 sensor resolution settings available: 800, 1200 (default), 1600, 2400 and 3600 DPI. The higher the value, the more sensitive behavior, and the faster the cursor moves.
● Special buttons in the form of corrugated chips and the smooth surface of the case, the high strength of which is achieved through the use of scratch-resistant ABS plastic.
● Built-in 800mAh battery, can be charged by USB cable, provides a whole day of work in just 3 minutes of charging, and up to 50 days of working time with full charge.
● Works on any surface - table, sofa, cloth, leather, etc.
● Light and compact, weighs only 98g even with the battery installed.
The Lofree wireless mouse is made in a bright but pleasant color palette - blue, red, and white, can become part of any decor, adds a little different color to your office and living areas: https://gearvita.com/xiaomi-lofree-ep115-wireless-mouse.html
You may also like:
amazfit bip
xiaomi wireless charger
Product Features:
You may also like:
amazfit bip
