These fantasy things are decorative only. What was the owner thinking when he figured he'd try to chop wood with it? Ya gotta buy the right tool if it's actually gonna be put to work.
Well, I have chopped frozen, sap filled maple with mine. No ill effects. It got a bit dirtier. At the end, it was still shaving. I've seen them cut down and limb trees handily. I've seen them thrown, and bounced. They are not wood axes. You don't have a use for one? That's fine. Mine is not "work" related. I use it for smiles. I don't have a real use for quite a few of my knives, or guns for that matter.
I grew up cutting down trees all my life. We used wood to heat our home. I grew up with chain saws, and axes. My father still heats with wood.
A tactical hawk with a sharpened beard is not a woodsman's tool. I don't need some crotchety old codger to tell me that, but your inability to see a use for them does not make them fantasy or decorative. Some of my swords and battle axes may well indeed qualify as much less useless than that hawk. In fact, most of my knives, both big and small, folding and fixed, are overkill. More expensive than I need. Better steel than I need. Higher tolerance than I need. You might as well tell me my stereo is too loud. Or my TV is too big, or my motorcycle too fast or loud.
There are a series of 13 video's titled "kill devil cutting a car part" numbered 1-13 where a guy takes a "fantasy" hawk from the same company Swamprat, made of the same steel, with the same heat treat, only thinner steel, and cuts a car in half. Top to bottom, all the way in half. He literally halves the car. Here is the first of the 13 video's. (
http://www.youtube.com/watch?v=mCPvSkfWzpA)
I could link them for you, but you won't watch them, because you have made up your mind. Yes, a massive saw would have done the same job in 1/100 of the time, but it would not fit on your pack, or belt. You could also bust a padlock with one, without carrying bolt cutters too, but that discussion has already been had too.
Puncture tires, gas tanks, cut through a hardened door, cut around a strike plate on a door you can't kick in. But, again, for me it is just a smile inducing fun design.
I throw hawks and axes for entertainment. I don't "need" a full tang high end, super steel hawk. I have basic traditional designs that work fine, and cost a heck of a lot less.
The tip on the beard on that hawk is thin. It is nasty pointy, and if used for hooking some one's arm, or neck, or leg, is going to do exactly what it is supposed to do. Cause a big ripping wound. The back spike is also much pointier than it needs to be, but I can tell you it penetrates even frozen hard wood with ease. It would do the same against modern body armor, and likely a modern ballistic helmet too. After owning one, and using one, I don't find it to be fantasy or decorative only. I'm not planning on using to build a cabin, or heat a home, but after actual experience I like mine just fine.
I can also say, after years of use, and over 15 different models used, Busse, Swamprat, and Scrapyard make fantastic hard use tools, with a great warranty, and excellent steels.
They hold their value extremely well. I would be hard pressed to think of another brand of knife that retains its value as well after use. They also have a fantastic warranty. If you manage to break one on accident, they will replace it.
Good stuff.
